Equation of a plane perpendicular to 2 other planes
The discussion centers on finding the equation of a plane that passes through the origin and is perpendicular to two given planes: x - y + z = 5 and 2x + y - 2z = 7. The solution involves determining the normal vectors of the two planes, which are (1, -1, 1) and (2, 1, -2), respectively. The cross product of these normal vectors yields the normal vector for the desired plane, which can then be used to formulate the equation in the form (x - 0) + (y - 0) + (z - 0) = 0.
  • Understanding of normal vectors in three-dimensional geometry
  • Knowledge of cross product operations
  • Familiarity with plane equations in the form Ax + By + Cz = D
  • Basic vector algebra
  • Study the properties of normal vectors in 3D space
  • Learn how to compute the cross product of two vectors
  • Explore the derivation of plane equations from normal vectors
  • Practice solving problems involving multiple planes and their intersections
Students and professionals in mathematics, physics, and engineering who are working with three-dimensional geometry and need to understand the relationships between multiple planes.
XtremeThunder
Greetings, I am have a bit of a problem getting started on the following problem. The only thing that is confusing me is I am use to seeing a problem like this be perpendicular to 1 plane and not 2.
The problem I am working with is as follows:
Find the equation of a plane through the origin and perpendicular to the planes given by x-y+z=5 and 2x+y-2z=7.
I just need some direction on where to start.
Edit:
I am not quite sure what to do with both planes given.
The final equation should look similar to the following, correct?:
?(x-0)+?(y-0)+?(z-0)=0. Again, I am not sure how to come up with the coefficients using two given planes.
I spent about 4 hours on this problem and feel really lost and stupid!
-Joe
Are you familiar with the concept of normal vector ?
Yes, I am familiar with the concept of a normal vector.
Would I be correct in saying each plane's normal vector is i-j+k and 2i+j-2k, or is that totally off base?
Or would I use the cross product between the two?
Yes,exactly. If the new plane is perpendicular to both the given planes, its normal vector must be perpendicular to the normal vectors of both given planes- and thus parallel to the cross product of the two normal vectors
The coefficients of the equation of my first post (?(x-0)+?(y-0)+?(z-0)=0) would be the coefficients of the result of the cross product between the two normal vectors i-j+k and 2i+j-2k, correct, which would be the final answer?
  • · Replies 21 ·
