What Are the Equilibrium Concentrations and Kc for 2NO(g) + Br2(g) ⇌ 2NOBr(g)?
The discussion focuses on determining the equilibrium concentrations and the equilibrium constant (Kc) for the reaction 2NO(g) + Br2(g) ⇌ 2NOBr(g). Initial concentrations are given as [NO] = 2.5 M, [Br2] = 5.0 M, and [NOBr] = 1.0 M, with changes leading to equilibrium concentrations of [NO] = 2.0 M, [Br2] = 4.75 M, and [NOBr] = 1.5 M. The values for the changes in concentration are calculated as P = 0.5 M, Q = 0.25 M, R = 4.75 M, and S = 1.5 M. The correct equilibrium constant expression is Kc = [NOBr]^2 / ([NO]^2 * [Br2]), resulting in a calculated Kc value of approximately 2.67 molar^-1. Confusion arises regarding the direction of the reaction, but the calculations for equilibrium concentrations and Kc are confirmed as correct.
a7med2009
Given 2NO(g) + Br2(g) <--------_____> 2NOBr(g),
Concentration (M) [NO] [Br2] [NOBr]
Initial 2.5 5.0 1.0
Change P Q +0.5
Equilibrium 2.0 R S
Find P,Q,R,S and Give the correct equilibrium constant expression for the above reaction and
calculate Kc.
Initial 2.5 5.0 1.0
Change P Q +0.5
Equilibrium 2.0 R S
calculate Kc.
What is the difference between 2.5 and 2.0?
I got the first part
p=0.5 ,Q=0.25, R=4.75 , s=1.5
but for Kc
is it Kc=[NOBr]^2 /[NO]^2 [Br2]
or Kc=[NO]^2 [Br2]/[NOBr]^2
What is the generic equation for any equilibrium constant, say A + B <-> C + D?
Are you sure about Q & R?
2NO(g) + Br2(g) <----___> http://www.freeimagehosting.net/uploads/b72c8010cb.jpg 2NOBr(g),
2.5 5.0 1.0
Since the total change in conc of [NOBr] is given as +0.5
so x[ extant of reaction]=0.50M (2mole NO to 2mole NOBr)
Now using the general expression
At eqm [NO] =intial conc- extant of reaction =2.5-0.5=2.0M
[Br2] = initial conc-(extant of reaction/2) =5.0-(0.5/2)=4.75M
[NOBr] = initial conc+ extant of reaction =1.0+0.5 =1.5M
So P=0.5M Q= 0.25 M R= 4.75M S=1.5M
Kc =[NOBr]2/[NO]2*[Br2]= (1.5)2/(2.0)2*(4.75) =2.671875
(b) Give the correct equilibrium constant expression for the above reaction and
calculateKc.
Kc =[NOBr]2/[NO]2*[Br2]= (1.5)2 (morality)2/((2.0)2(morality)2 *(4.75) (molarity))=2.671875 molar-1
Unit of Kc= liter.mole-1
is it correct , the problem is that the arrow is going from right first the coming back (from
2NOBr(g) first to 2NO(g) + Br2(g) ) I'm confused,,,
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
