Equilibrium Tension Along a Curved String
Raghav anand
A light inextensible string of length l hangs on two pegs attached to parallel walls separated by a height. A small frictionless pulley of weight Wp is attached to a block of weight Wb. When it is placed on the string, the string becomes taut and pulley runs on the string till equilibrium is established. What is the tension in the string?
F=ma; vertically and horizontally
x, l, Wp, Wb are the given variables
The angles the tension force makes with the pulley at the point of contact are equal as the horizontal components of tension are equal. When equating the vertical component to mg, I only get an expression for T in terms of an unknown variable h. I eliminated y by using the two triangles marked in the diagram. Any thoughts?
I gather the distance between the walls is x.
You should post more of your working, preferably typed, not as an image.
You should be able to find the angle in terms of l and x only - it's just geometry. Hint: project the line of one side of the string down until it reaches the opposite wall. After that it is straightforward.
I will make sure to write more from next time. Got the answer, thanks!
