Equivalent Circuit of 4 Capacitors in Series/Parallel Combination
  • Context: Engineering
  • Thread starter Thread starter animesh184
    Circuit
The discussion revolves around determining the equivalent capacitance of a circuit involving four capacitors arranged in a series/parallel combination. Participants explore the implications of the circuit's physical layout, dielectric properties, and the complexity introduced by the geometry of the capacitors.
  • Some participants question whether the circuit is a coupled line circuit and note the lack of information regarding dimensions and line width necessary for analysis.
  • There are suggestions to find the equivalent capacitance between points P and Q, with multiple participants reiterating this need.
  • One participant emphasizes the importance of specifying the dielectric constant and dimensions of the structure to accurately discuss the capacitance.
  • Another participant proposes that if the structure consists of parallel plates with dimensions much larger than the separation distance, it can be approximated as a parallel plate capacitor.
  • Concerns are raised about the complexity of the problem due to insufficient information, particularly regarding the frequency of operation and the geometry of the capacitors.
  • One participant suggests using a field solver for modeling due to the complex geometry, indicating that simple formulas may not apply.
  • Another participant speculates that the end plates may be treated as wires, simplifying the analysis to a series/parallel combination of four capacitors.
Participants express various viewpoints on how to approach the problem, with no consensus on the best method or the implications of the circuit's geometry. The discussion remains unresolved regarding the exact equivalent capacitance and the necessary parameters for calculation.
Limitations include missing assumptions about the physical layout, dielectric properties, and the frequency of operation, which affect the analysis of the circuit.
Please increase brightness of your screen and then see it.
Is this a coupled line circuit? P and Q is the input/output ( interchangeable). If so, you don't have nearly enough info on the length and the line width. It's been a while I studied couplelines. This likely to be a band pass filter type. You really have to have the physical layout to know more, it cannot be just a schematic.
have to find eqivalent capacitance between p an q
have to find eqivalent capacitance between P anQ
You need to draw out the dimension of the structure, specify the dielectric constant. You don't have nearly enough information to even talk here.
If the structure composes of parallel plates that the length and width is much larger than the d, then you can approximate by parallel plate capacitor. But if it's not, then it can get really complicated. Also it depends on the frequency you are working with also. You are asking a question that can potentially be very complicated with almost no information.
The only possibility this can be simpler is if you have parallel plates with large area and you don't need exact value. Then it's just P connect to Q with a parallel combination of a capacitor ##C_{PQ}## comprises of one plate from the P and the other from Q. Then ##C_{PQ}## is in parallel with a series combination of two capacitors ##C_{PA}## and ##C_{AQ}## that formed from plate of P to A, A to Q respectively.
And even at that, the largest dimension of the structure has to be less than ##\frac 1 {20\lambda}## of the highest frequency you use.
Imagine you put a positive charge on P, what charge does that induce on the other plates? Once you have that you can figure out the total capacitance using a formula involving A and d.
I would use FastCap
I am curious where the OP got this, it sure does not look like homework. The eA/d formula (or any other closed form expression) will not work here due to the complex geometry, modeling with a field solver is necessary. As yungman pointed out, a lot of the necessary geometry is not shown, particularly what is happening in the third dimension.
My guess is that you are meant to ignore any field/capacitive effect of the end plates (eg the vertical lines in the drawing). Treat these as wires only.
Then don't you just have 4 capacitors connected in a series/parallel combination? Perhaps I'm too rusty.
  • · Replies 16 ·
10K
