Equivalent Impedance: 1MicroF Cap, 1kOhm & 200mH Inductor
  • Context: MHB
  • Thread starter Thread starter jmartin
The discussion revolves around calculating the equivalent impedance of a circuit consisting of a 1-microF capacitor and a 1-kOhm resistor in parallel, which is then connected in series with a 200-mH inductor. The analysis is conducted at a frequency of ω=1 krad/s, focusing on the application of impedance formulas for resistors, capacitors, and inductors.
  • Participants discuss the individual impedances of the resistor, inductor, and capacitor, with values provided as 1000 ohms, 200j, and 1000/j respectively.
  • There is a clarification on how to combine impedances in series and parallel, with emphasis on the correct mathematical treatment of these combinations.
  • One participant expresses uncertainty about their calculations, leading to a collaborative effort to identify and correct the mistake in the equivalent impedance calculation.
  • A later reply provides a detailed step-by-step calculation of the equivalent impedance, highlighting the process of combining the impedances and simplifying the expression.
Participants generally agree on the methods for calculating individual impedances and combining them, but there is a moment of uncertainty regarding the calculations that leads to a correction. The final equivalent impedance calculation is not universally agreed upon until the error is identified.
The discussion includes some unresolved mathematical steps and assumptions regarding the treatment of complex numbers in impedance calculations.
jmartin
Question: A 1-microF capacitor and a 1-kOhm resistor are connected in parallel, and this parallel combination is connected in series with a 200-mH inductor. Find the equivalent impedance of the connection at w=1 krad/s.
Relevant Equations: Z=R for a resistor, Z=jwl for an inductor, and Z=1/(jwC) for a capacitor (w=omega)
I know to find equivalent impedance you use the above equations, but I am not sure how to proceed with this question. Any help would be appreciated.
Mathematics news on Phys.org
So we have the following:
And you have reported $\omega=1E3$ rad/s. So what are the individual impedances?
The impedances are 1000 ohms for the resistor, 200j for the inductor, and 1000/j for the capacitor.
Excellent! I'd go ahead and write $1000/j=-1000j$, since $\dfrac{1}{j}=-j$.
So, now we have to consider how these elements combine. How are the components connected? And how do impedances combine in series? Parallel?
The capacitor and resistor are connected in parallel, and this combination is in series with the inductor. Impedances are added normally in series and inversely in parallel.
Excellent! So your equivalent impedance is...
I am getting 1000-487j as the answer. I'm not sure what I am doing wrong in my calculations.
Ok, so we should have
\begin{align*}Z_{\text{eq}}&=200j+(1000) \| (-1000j) \\
&=200j+\frac{(1000)(-1000j)}{1000-1000j} \\
&=200j+\frac{-1000j}{1-j} \\
&=200j+\frac{-1000j}{1-j} \cdot \frac{1+j}{1+j} \\
&=200j+\frac{-1000j+1000}{2} \\
&=200j+500-500j \\
&=500-300j.
\end{align*}
Can you see your error now?
Yes I found where I made my mistake. Thank you so much for your help!
You're quite welcome! Any time!
10K
  • · Replies 16 ·
