Equivalent Resistance in partial parallel/series cicuit
The discussion focuses on calculating the equivalent resistance between points A and B in a circuit with both series and parallel components. Initial attempts to simplify the circuit led to confusion regarding the arrangement of resistors, particularly the placement of a 3-ohm resistor affecting series and parallel combinations. Correct identification of series and parallel relationships is crucial, with emphasis on combining resistors step by step to avoid errors. The final equivalent resistance can be derived by carefully applying the series and parallel resistance formulas. Understanding the configuration of resistors is essential for accurate calculations in circuit analysis.
thatgirlyouknow
Find the equivalent resistance between points A and B in the drawing.
Rseries = R1+R2+R3...
Rparallel: 1/Rp = 1/R1+1/R2+1/R3...
Reducing it down:
1/8+1/9 = 1/R1 = 4.235
That's in parallel with 20, so:
1/20+1/4.235 = 3.495 ohms
3, 4, and 6 are in series:
3+4+6 = 13 ohms
Add that to the previous and you have 16.495 ohms, which is incorrect.
Is one parallel and I'm not adding it as such? Or should I combine differently?
Thanks so much!
thatgirlyouknow said:
Reducing it down:
Good. R1 = 4.235 (not 1/R1).
Nope. The 3 ohm resistor is in the way.
So then 20 and 3 are in series, right?
20+3=23 ohms
So now my drawing has:
23 ohms . 4 ohms
4.235 ohms
. 6 ohms
Would the 4 and 6 be considered series?
4+6 are in series
9+8 are in parallel
3 and 20 are not in series!
You need to do this step by step...
6+4 = 10
1/8 + 1/9 = 17/72
now you have
------3 -----------
-20------17/72--10
Next you have 17/72 and 10 in parallel.
1/10+72/17 = 737/170
-- -- 3 -------
-20------737/170
Now the 3 and 737/170 are in series so just add them to get
-20-------1147/170
Now these are in parallel you can solve!
When you added for 17/72 and 10 in parallel, shouldn't it have been 1/4.235+1/10 = 1/R = 2.975?
so then with
------3--------
20 2.975
So now which should I combine first?
first take this and then you shall have the feel of the question much better..""
General rules for doing the reduction process include:
1. Two (or more) resistors with their heads directly connected together and their tails directly connected together are in parallel, and they can be reduced to one resistor using the equivalent resistance equation for resistors in parallel.
2. Two resistors connected together so that the tail of one is connected to the head of the next, with no other path for the current to take along the line connecting them, are in series and can be reduced to one equivalent resistor.
Finally, remember that for resistors in series, the current is the same for each resistor, and for resistors in parallel, the voltage is the same for each one
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
