Estimating the radius of planets
  • Thread starter Thread starter trina1990
    Planets Radius
The discussion revolves around estimating the radius of a planet based on the escape velocity needed for a person to leap vertically upward. The initial calculations involve using the formula for escape velocity, but the participant struggles with determining the escape velocity, denoted as 'k', and its relation to the planet's gravitational acceleration. A key point raised is that the jumping speed of a person is independent of the planet's gravitational acceleration, which complicates the calculations. The participant seeks clarification on how to proceed without sufficient information, particularly regarding the gravitational conditions of the planet. The conversation highlights the need for a deeper understanding of the relationship between jumping speed and gravitational forces in this context.
trina1990
there' s a problem that tells " estimate the radius of a planet that a man can escape it's gravitation only by leaping vertically upward..that density of the planet is assumed to be same as earth..."
it seems to me that there's not enough information provided here to solve the problem..
i tried it this way,
escape velocity V= root over(2GM/R)
so R=2GM/V^2
and i fianally ended up with
R^2=3k^2/8pi PG ( here k=escape velocity of the planet, p= density of planet, G= gravitational constant)
now my question is i still don know the escape velocity of the planet, then should i guess here the velocity or i should apply other formula or other way to solve it...please help me solve it out....
Astronomy news on Phys.org
so R=2GM/V^2
What you are looking for are the conditions for which k= the vertical jumping speed of a man. So what does that suggest to you as to what you should use for k in your equation?
but unfortunately i could not get the point of estimating the vertical jumping speed of a man =k
may i try this way?
k=gt...?
then again i have to know the gravitational acceleration of the planet...another variable.
please provide me the specificity of theses problem...where the mystery of solution lies?
may i try this way?
k=gt...?
Hint: His jumping speed is independent the g of the planet.
hmm..i didn't get it
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
