Estimation, negative binomial variable
The discussion revolves around the estimation of the success probability in a negative binomial variable, specifically examining the differences between two estimators: (r-1)/(x+r-1) and r/(x+r). Participants explore the implications of these estimators in the context of negative binomial experiments, seeking intuitive understanding of why one is unbiased while the other tends to overestimate the success probability.
  • One participant presents the negative binomial variable x, defined by parameters p and r, and discusses the unbiased estimator (r-1)/(x+r-1) versus the biased estimator r/(x+r).
  • Another participant suggests that the sampling plan influences the estimator, noting that different sequences of successes and failures affect the estimation process.
  • A participant highlights the expected value of x and its relationship to the estimators, indicating that r/(E(X)+r) converges to p when averaging over many experiments.
  • Concerns are raised about the intuitive understanding of why (r-1)/(x+r-1) is unbiased and why r/(x+r) overestimates p, with references to Jensen's inequality as a potential tool for analysis.
  • One participant proposes an intuitive explanation that the negative binomial process is oriented towards achieving successes, suggesting that this inherent bias necessitates the adjustment of subtracting one from r.
Participants express varying levels of agreement on the technical aspects of the estimators and their properties, but there is no consensus on the intuitive explanations for why one estimator is unbiased while the other is biased. The discussion remains unresolved regarding the best intuitive understanding of the negative binomial process.
Participants acknowledge the complexity of the estimators and the need for careful consideration of the sampling process. There are references to expected values and moments, but no definitive conclusions are drawn about the intuitive explanations offered.
skwey
Hey, there's this thing I can't wrap my head around.
Let's say we have a negative binomial variable x, with parameters p and r. That is, x is the number of failures we get before the rth sucess, while looking at random bernolli variables with sucsess rate p.
It can be shown that (r-1)/(x+r-1) is an unbiased estimator for p. So let's say before you start the experiment you want 5 sucesses, then the failures x is the variable. Let's say you get SFFSSFSFFS then the estimation for p=4/9=0,444444
Here comes the tricky part. One intuitive way the estimate the sucsessrate is to use r/(x+r), which I think is more logical(it is also actually the maximum-lilelyhood estimator, but biased). I mean, if you have 10 trials and 5 sucsesses 5/10 wouldn't be that bad would it? However this is not correct, and on avarage in the long run, since this is not a binomial experiment, but a negative binomial, it will tend to overestimate p.
But why does this tend to overestimate p, and why does subtracting 1 from r, give the correct answer? I know it can be shown from calculating the expected value of (r-1)/(x+r-1) that it is unbiased, but I am looking for a more intuitive answer. Which properties does the negative binomal model have that gives you the correct estimator, on avarage in the long run, if you subtract 1 from r.
I don't know how to justify that exact result intuitively and I haven't double checked you formulas, but one can form an intuition on the general idea that a sampling plan affects an estimator. If you agree to toss a coin 2 times then you estimate p from 4 possible sequences of success S and failure F. This includes the possibility F,F. If you agree to toss a coin until the first head comes up, you eliminate the possibility of the sequence FF and you add the possibilities of longer sequences. However, you never allow sequences that are all failures such as F,F,F or F,F,F,F. So, in a manner of speaking, it is your sampling plan that biases the estimate based on the ratio (number of successes)/(total number of trials).
As a simpler example, suppose you agree to toss a coin until the total number of heads is equal to the total number of tails. That sampling plan certainly affects an estimator based on the ratio of heads to total tosses.
I see what you are saying Stephen Tashi, the sampling process obvioiusly alters the way we estimate, it is just interesting that it is so close to the binomial forumula except that you subtract 1 from r.
Another thing that makes this make you wonder more is if you look at the expected value of x.
E(X)=r*(1-p)/p, shuffling this gives p=r/( E(X)+r ). This says that if we do a negative binomial experiment many times, with the same r, and take the avarage of the x values, then now r/(x(avarage)+r) will converge to p.
But if you want to use (r-1)/(x+r-1) to get p, when you have many experiments, you have to use the avarage of the whole (r-1)/(x+r-1), not (r-1)/(x(avarage)+r-1). Since the expected value of (r-1)/(x+r-1) is p.
This is also very difficult to understand.
That looks about right, what it's saying is that E[(r-1)/(X+r-1)] = p = r/(E[X]+r) for the NB distribution. Jensen's inequality might help to show if r/(X+r) is overestimating p.
Thanks for your contribution. I don't know about Jensens inequality, but you don't need it to show that r/(X+r) overestimates p: It is easy to show that E[(r-1)/(x+r-1)] is p. And also that r/(x+r) > (r-1)/(x+r-1) for all x>0, then it is logical that r/(x+r) overestimates p, because when you calculate it's expeted value, all its moments is bigger than the moments of (r-1)/(x+r-1), since r/(x+r) > (r-1)/(x+r-1) hence it's expected value must be bigger than p. I am talking about the first moment f(x)*p(x). Where f(x) is r/(x+r) or f(x)=(r-1)/(r-1+x)
But this is very technical and not really an intuitive explanation, which explains it by just calculating it. I thought of one intuitive answer, which I am not sure of at all, but maybe you guys can accept or reject it?: Is it fair to say that the negative binomial process is on a team with the sucsess and not the failures? I mean if r is 5 we accept SSSSS, but we will continue if we get FFFFF, so in a way the process is allways fighting for S?, it will never stop uintil it has enough sucsesses. And since the process is allways "fighting" for sucesses, the end result will tend to have more sucesses than the population really has, so we have to correct for this. That is why we have to subtract one from r, that is, we subtract one from the sucesses, and use (r-1)/(r-1+x) and not r/(r+x). Is this a fair explanation, or is it not ok?
  • · Replies 0 ·
  • · Replies 16 ·
9K
