Can't Find a Correct Method to Integrate \int (t - 2)^2\sqrt{t}\,dt?
  • Thread starter Thread starter KungPeng Zhou
    Indefinite integral
The discussion focuses on the difficulty of integrating the expression ∫(t - 2)²√t dt and the challenges faced in finding a suitable substitution method. A participant shares a successful substitution method for a similar integral, ∫x√(2 + x²) dx, but struggles to apply the same technique to the current problem. Suggestions are made regarding the use of LaTeX for formatting mathematical expressions, emphasizing the importance of clear communication in mathematical discussions. Ultimately, the participants acknowledge the complexity of the integral and the need for a different approach.
KungPeng Zhou
\int x^{2}\sqrt{2+x}dx
The Substitution Rule,
Table of Indefinite Integrals
When I encountereD this kind of question before.For example
\int x\sqrt{2+x^{2}}dx
We make the Substitution t=x^{2}+2,because its differential is dt=2xdx,so we get \int x\sqrt{2+x^{2}}=1/2\int\sqrt{t}dt,then we can get the answer easily
But the question,it seems that I can't use the way to solve the question.I can't find a correct commutation method.
Try putting #### at head and #### at tail of your math code to show it properly.
Sorry,but I can't understand you.Could you please tell how to show my math code properly?Now I just can use these math code.
KungPeng Zhou said:
Homework Statement: \int x^{2}\sqrt{2+x}\,dx
Relevant Equations: The Substitution Rule,
\int x\sqrt{2+x^{2}}\,dx
We make the Substitution t=x^{2}+2,because its differential is dt=2xdx[/tex],so we get \int x\sqrt{2+x^{2}}\,dx =\frac12 \int\sqrt{t}\,dt, then we can get the answer easily<br /> But the question,it seems that I can&#039;t use the way to solve the question.I can&#039;t find a correct commutation method.<br />
<br /> <br /> Did you consider t = x + 2, dx = dt?
Example for \frac{\pi}{2}
##\frac{\pi}{2}##
\frac{\pi}{2}
Why don't you try these two ways for Latex in your post ?
Look at https://www.physicsforums.com/help/latexhelp/.
KungPeng Zhou said:
Homework Statement: ##\int x^{2}\sqrt{2+x}dx##
##\int x\sqrt{2+x^{2}}dx##
We make the Substitution ##t=x^{2}+2##,because its differential is ##dt=2xdx##,so we get ##\int x\sqrt{2+x^{2}}=1/2\int\sqrt{t}dt##,then we can get the answer easily
I'm not quite sure what you actually want to know. The LaTeX issue is addressed above and in the link.
The integral works as follows and is explained here:
https://www.physicsforums.com/threads/substitution-in-a-definite-integral.1054611/#post-6919864
Ithe seems that we still can't solve it with this way...
You can't integrate \int (t - 2)^2\sqrt{t}\,dt = \int t^{5/2} - 4t^{3/2} + 4t^{1/2}\,dt?
Likes KungPeng Zhou
Yes,you are right.
  • · Replies 105 ·
  • · Replies 22 ·
  • · Replies 23 ·
