Evaluating a Surface Integral for S: How Can the Given Formula be Used?
7 replies · 3K views
wifi
Problem:
Use the fact that [tex]\int_S \vec{v} \cdot d\vec{S}=\int_S \vec{v} \cdot \frac{\nabla f}{\partial f/\partial x} dy\ dz[/tex]
to evaluate the integral for ##S=\{(x,y,z):y=x^2 ; 0 \geq x \geq 2; 0 \geq z \geq 3 \}## and ##\vec{v}=(3z^2, 6, 6xz)##.
Attempt at a Solution:
I'm having trouble setting up this integral. If I knew what ##f## was, I could easily calculate the gradient, as well as the partial wrt to x. I'd still need to figure out the limits of integration though.
f(x,y,z) ought to be the scalar function describing the surface S through the relationship:
f(x,y,z)=0
f(x,y,z)=0
Hmm. I'm not sure you'd get this from the info given. Any hints?
Because
1. It fits. Sort of (I admit I haven't seen closely, though).
2. Otherwise, it would be utterly meaningless, since you would have no way to evaluate the second expression due to lack of knowledge of f.
More specifically I meant, how would you find ##f## analytically from this info given?
From here:
If [itex]y = x^2[/itex] then [itex]y - x^2 = 0[/itex].
(Your inequalities are the wrong way round: you want [itex]0 \leq x \leq 2[/itex] etc.)
pasmith said:
From here:
So ##f(x,y,z)=y-x^2##?
I would parameterize the surface as ##\vec R(x,z)## and use the formula$$
\iint \vec v\cdot d\vec S =\pm \iint_{x,z}\vec v \cdot \vec R_x\times \vec R_z~dxdz$$where the choice of signs depends on the orientation of the surface which, by the way, you need to specify.
