Evaluating an Improper Integral using a Double Integral
The discussion focuses on evaluating the improper integral of the function involving the difference of arctangents. The integrand is rewritten as a double integral, where the limits of integration are expressed in terms of the variable x. Participants explore changing the order of integration and adjusting the limits accordingly, leading to a new setup that simplifies the evaluation. The final steps confirm that the integral converges to a specific value, with participants discussing the legality of moving terms within the integrals. The conclusion reached is that the integral evaluates to (π/2)ln(3), confirming the correctness of the approach taken.
whoareyou
Here is a more interesting problem to consider. We want to evaluate the improper integral
\intop_{0}^{\infty}\frac{\tan^{-1}(6x)-\tan^{-1}(2x)}{x}dx
Do it by rewriting the numerator of the integrand as \intop_{f(x)}^{g(x)}h(y)dy for appropriate f, g, h and then reversing the order of integration in the resulting double integral.
Writing the numerator of the integrand as an integral:
\Rightarrow\intop_{0}^{\infty}\frac{\intop_{2x}^{6x}\frac{1}{1+y^{2}}dy}{x}dx
\Rightarrow\intop_{0}^{\infty}\frac{1}{x}\intop_{2x}^{6x}\frac{1}{1+y^{2}}dydx
\Rightarrow\intop_{2x}^{6x}\frac{1}{x}\intop_{0}^{\infty}\frac{1}{1+y^{2}}dxdy
But it seems to be a dead end from here since you have to evaluate x at infinity and 0. I don't know how to continue from here.
Can you change the limits of integration so the interior limits are in terms of y? And the exterior limits might be for y from zero to infinity.
Minor point. The "implies" arrow, ##\Rightarrow##, should not be used in place of =; i.e., between expressions that have equal values. Because it means "implies" you also shouldn't use it is the first symbol you write in your work.
"Implies" should be used between two statements (generally equations or inequalities) where the first being true means that the following statement will also be true.
As a simple example,
$$x^2 - 3x + 2 = 0$$
$$\Rightarrow (x - 2)(x - 1) = 0$$
$$\Rightarrow x = 2 \text{ or } x = 1$$
I don't understand? The question specifically says that the bounds for the integral in the numerator should be functions of x.
Edit: I think I made a mistake with the bounds when I switched the order of integration. I think it should be:
\intop_{y/2}^{y/6}\frac{1}{x}\intop_{0}^{\infty}\frac{1}{1+y^{2}}dxdy
But I still run into the same problem ...
Thanks for the explanation! I always try to make my answers more formal by trying to write my solutions as they would appear in the textbook.
Your 1/x should be inside the integral with respect to x. Also the limits in terms of y have to be on the inside integral with respect to x. That should take care if the infinity problem.
You start with
\int_{x=0}^{\infty} \int_{y=2x}^{6x} \cdots \: dy \: dx
Here, ##x## goes from 0 to ##\infty## and ##y## goes from ##2x## to ##6x##. So, if you draw an ##xy## diagram and plot the integration region, you will see that any ##y## from ##0## to ##\infty## can occur, and for any fixed ##y > 0##, ##x## will run from ##y/6## to ##y/2##. Thus, you can write, instead:
\int_{y=0}^{\infty} \int_{x=y/6}^{y/3} \cdots \: dx \: dy
But it seems to be a dead end from here since you have to evaluate x at infinity and 0. I don't know how to continue from here.[/QUOTE]
When you change the order of integration you have to change the limits accordingly. You need to draw a picture of the region of integration to see the dxdy limits. Draw a picture of the region described in the first integral above between ##y=2x## and ##y=6x## as ##x## goes from ##0## to ##\infty##. Then set it up as a dxdy integral using the picture.
Following your suggestions, I got this:
$$\intop_{0}^{\infty}\frac{\tan^{-1}(6x)-\tan^{-1}(2x)}{x}dx$$
=\intop_{0}^{\infty}\frac{\intop_{2x}^{6x}\frac{1}{1+y^{2}}dy}{x}dx
=\intop_{0}^{\infty}\frac{1}{x}\intop_{2x}^{6x}\frac{1}{1+y^{2}}dydx
=\intop_{0}^{\infty}\intop_{2x}^{6x}\frac{1}{x}\frac{1}{1+y^{2}}dydx
=\intop_{0}^{\infty}\intop_{y/6}^{y/2}\frac{1}{x}\frac{1}{1+y^{2}}dxdy
=\intop_{0}^{\infty}\frac{1}{1+y^{2}}\intop_{y/6}^{y/2}\frac{1}{x}dxdy
=\intop_{0}^{\infty}\frac{1}{1+y^{2}}[\ln(x)]^{y/2}_{y/6}dy
=\intop_{0}^{\infty}\frac{1}{1+y^{2}}[\ln(3)]dy
=\ln(3)\intop_{0}^{\infty}\frac{1}{1+y^{2}}dy
=\ln(3)[\tan^{-1}(x)]^{\infty}_{0}
=\frac{\pi}{2}\ln(3)
This seems to be the correct answer. However, I'm unsure of the validity of the steps. Like in the third step, is it legal to just bring the 1/x inside the second integral?
Yes, that is always valid. As far as integration with respect to y is concerned, "x" is a constant. \frac{1}{x}\int_{2x}^{6x} \frac{1}{x^2+ 1} dy= \int_{2x}^{6x} \frac{1}{x}\frac{1}{y^2+ 1} dy is exactly the same as C\int_{2x}^{6x} \frac{1}{x^2+ 1} dy= \int_{2x}^{6x} C\frac{1}{y^2+ 1} dy
  • · Replies 105 ·
  • · Replies 19 ·
