?Evaluating Double Integral Using Polar Coords
10 replies · 4K views
joemama69
Use polar coords to evaluate the double integral x3 + xy2dydx from y = -(9-x2)1/2 to (9-x2)1/2, and x = 0 to 3
So the region is a half circle of radius 3, centered @ the origin, with only the possitive x side, (right side of circle)
x = rcosQ, y = rsinQ
the integral is r3cos3Q + r3cosQsinQ drdQ
after integration with respect to r i get and pluging in the limits
84/4 cos^3 Q + 81/4 cosQsinQ dQ
i looked up the integrals of cos^3Q in the back of my book and it is quite complex. Have i made any mistakes thus far, and is there an easier way to evaluate it
Also if you go from Cartesian to polar coordinates [itex]dxdy \Rightarrow r dr d\theta[/itex].
While not relevant to this problem [itex]\cos^3x[/itex] is easily integrated by writing it as [itex]\cos x (1-\sin^2x)[/itex] and substituting [itex]u=\sin x[/itex].
i think i messed up somehwere
[tex]\int r^3cosQdrdQ[/tex] = .25r^4cosQ from 0 to 3
=[tex]\int81/4 cosQ dQ[/tex] from 0 to pi = 81/4 sinQ from 0 to pi
sin(0) = 0, sin (pi) = 0
i got an answer of 0
You forgot that when you transform from Cartesian to polar coordinates you have to add the Jacobian r ([itex]dx dy \Rightarrow r dr d\theta[/itex]). Secondly your limits for [itex]\theta[/itex] are off. You are integrating over the upper semi circle, but that is not the right region to integrate over. Draw the circle and add the Cartesian limits, over what section should you be integrating?
Actually, he did include the "r" but you are correct that his limits of integration on [itex]\theta[/itex] are wrong.
uhhh huh, ok i didnt realize that mattered, i figured as long as it was 180 degrees it would be the same
but i think i did mess up the r
x(x2 + y2) = rcosQ* r2 = r3cosQ
then i add the jacobian r and my integral is for r4cosQdrdQ
the only thing that changes is the 81/4 becomes 243/5
so the final answer is
243/5 + 243/5 = 486/5
