Evaporation of a solid in water vapor.
Evaporation of solids in water vapor is a confirmed phenomenon, applicable even to microscopic entities such as single cells. In a partially frozen pond, both exposed ice and water surfaces experience gross vaporization. The extent of net vaporization is contingent upon the ambient vapor pressure and the equilibrium vapor pressures over ice and water.
  • Understanding of vapor pressure concepts
  • Knowledge of phase transitions, specifically evaporation
  • Familiarity with thermodynamic principles
  • Basic comprehension of water's physical properties
  • Research the principles of vapor pressure and its effects on evaporation
  • Study phase transitions in different states of matter
  • Explore thermodynamic equations related to vaporization
  • Investigate the impact of temperature on equilibrium vapor pressures
Scientists, environmental researchers, and students studying thermodynamics and phase transitions, particularly those interested in the behavior of water in varying states.
mpzelen
Can a solid, no matter how small, even a single cell, be evaporated with water vapor from a pool of water?
Yes. In a partially frozen pond of water, any surface of ice exposed to the air will undergo gross vaporization and any surface of water exposed to the air will do the same. Whether there will be net vaporization depends upon the ambient vapor pressure and the two equilibrium vapor pressures--over ice and over water.
  • · Replies 20 ·
35K
  • · Replies 30 ·
13K
  • · Replies 32 ·
9K
