Evaporation of Water: Error in Formula?
The discussion centers on calculating water evaporation rates using various equations, with concerns raised about potential errors in formulas sourced from engineeringtoolbox.com. Users report inflated evaporation rates when applying these equations, particularly for pools, leading to unrealistic outcomes. Alternative equations were suggested, including one that factors in air velocity and vapor pressures, but these also yielded high evaporation estimates. Participants shared their calculations and experiences, noting that actual evaporation rates tend to be much lower, especially under typical conditions. The conversation highlights the need for accurate formulas and realistic expectations regarding water loss through evaporation.
t3sseract
I am trying to calculate the rate (g/m2) of water evaporation given Temperature, Humidity, Air Speed, elevation.
The best source of an equation for this I have found is from engineeringtoolbox.com, but I have found a possible error in their calculation. (I am in a far off land with no access to real textbooks)
The equation:
g = Θ A (xs - x) (1)
where
g = amount of evaporated water (kg/h)
Θ = (25 + 19 v) = evaporation coefficient (kg/m2h)
However, later on the example switches air speed units:
g = ( 25 + 19 (0.5 (m/s)) ) ( 25 (m) 20 (m) ) ( 0,019826 (kg/kg) - 0.0115 (kg/kg)) / 3600
= 0.04 kg/s
When I use this equation with m/s and kg/s, I get an inflated evaporation rate (their example alone provides and incredible evaporation rate for a pool).
Can anyone give me a confirmation of this equation?
Is there a more recommended equation for calculating evaporation(and a source)?
Thank you
:3
This should work.
M-dot= (A)(42.6+37.6V)(Pw-Pa)/Hv
where
m-dot= evaporation rate, kg/hr
A= surface area, m^2
V= air velocity over water surface, m/s
Pw= saturation vapor pressure at water temperature, mm Hg
Ps= saturation vapor pressure of air dew point, mm Hg
Hv= latent heat of vaporization of water at pool temperature, about 2270 KJ/Kg
This equation is also giving me inflated evaporation rates:
Using:
A = 9m2
V = 0.5m/s
Pw (at 25 deg. C) = 11.76 mmHg
Ps (at 50% RH) = 23.53 mmHg
Gives:
m-dot = 2.84 kg/hr
At this rate my pool will empty almost as fast as I can fill it.
I am using the following equations for computing the Pressures (in Pa, and in visualbasic)
Public Function Vap_Pres_Sat(TempK As Double) As Double
Vap_Pres_Sat = 22105649.25 * Exp((-27405.526 + 97.5413 * TempK + -0.146244 * TempK ^ 2 + 0.00012558 * TempK ^ 3 + -0.000000048502 * TempK ^ 4) / (4.34903 * TempK - 0.0039381 * TempK ^ 2))
End Function
Public Function Vap_Pres(TempK As Double, RH As Double) As Double
Vap_Pres = Vap_Pres_Sat(TempK) * RH
End Function
Pw@25 C = 23.71 mmHG
Ps@ 18 C = 15.46 mmHG ( 25 C air temp, 50% RH)
m-dot= 2 KG/hr, that is about .0022 cm/hr drop in water level for a 9 m^2 surface area
For a vapor pressure calculator goto:
www.csgnetwork.com/vaporpressurecalc.html
To review evaporation rate information goto:
"Measurement and analysis of Evaporation from an inactive outdoor swimming pool"
www.p2pays.org/ref/19/18985.pdf
I don't have a formula for you, however, I can tell you from experience that you can expect no more than a 1/2 inch of evaporation, for a full day, in the hottest of weather. You can expect increased evaporation if you are in a very windy area. If you think your evaporating too much water, turn the pool off overnight, if you've lost water overnite chances are you have a leak.
See
http://www.rlmartin.com/rspec/whatis/equations.htm
Bob S
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
