Existence of the Square Root Proof
The discussion focuses on the proof of the existence of square roots as presented in Apostol's Calculus, specifically in chapter 3, theorem 1.35. The key point is the establishment of the set S as nonempty, with the inclusion of the term a/(1+a) to demonstrate that it is positive and satisfies the condition a ≤ (1+a)². The proof utilizes the binomial theorem and the continuity of squaring to argue that the least upper bound (LUB) squared cannot exceed a. Participants express confusion regarding the derivation of certain steps, particularly the expression c = b - (b² - a)/(2b).
  • Apostol's Calculus, chapter 3, theorem 1.35
  • Understanding of the least upper bound (LUB) property
  • Familiarity with the binomial theorem
  • Knowledge of the intermediate value theorem and continuity
  • Study the proof of the least upper bound property in real analysis
  • Review the binomial theorem and its applications in calculus
  • Explore the continuity of functions, specifically squaring functions
  • Investigate alternative proofs of the existence of square roots in real numbers
Students of calculus, mathematicians interested in real analysis, and anyone seeking to understand the foundational proofs of square roots and their properties.
Ronnin
I was playing trying to work through a proof in Apostol's Calculus and can't quite understand a step noted. This is from chapter 3, theorem 1.35. Every nonnegative real number has a unique nonnegative square root. The part where you are establishing the set S as nonempty so you can use LUB it is stated that a/(1+a) is in the set S. I've seen different choices for this on other versions of this proof. When I first looked at this I figured it was in S for the reason that that would produce a square of a fraction which would produce something smaller than a. But it looks like this is then used with the binomial theorem to finish off the proof. I don't follow it. Can someone walk me through the logic in this one?
Indeed, \frac{a}{1+a} is in S because it is positive and because
\frac{a^2}{(1+a)^2}\leq a
To see this, note that this is equivalent to
a\leq (1+a)^2
or
a\leq 1+a^2+2a
And this is certainly true.
This book never ceases to make me feel stupid. Thanks Micro for making that clearer.
do you believe the intermediate value theorem? If so you only need to prove that squaring is continuous. since (a+h)^2 = a^2 + 2h + h^2, it is clear that making h small will make a^2 close to (a+h)^2. qed.
Now I'm lost again. We are trying to prove that the LUB^2 (LUB=b) cannot be any other value but a. From this point on I don't follow the proof at all. For instance to test if LUB^2>a he sets a number c=b-(b^2-a)/(2b). Where did that come from?
I know this is binomial trickery but I just don't see it. Any ideas?
  • · Replies 16 ·
  • · Replies 30 ·
