jocaxx
- 22
Expanded Science
João Carlos Holland de Barcellos
translated by Debora Policastro
“If truth were not the objective of philosophy, the Grimm brothers would have been the biggest philosophers in the world” (Jocax)
Abstract: initially, in this article, we present the foundation on which current science stands. Next, we explain the main stream of modern science, the “Popperian Falsificationism”, and show why the current criticism to the system is flawed. Later, we will prove that the “falsificationism” is logically inconsistent and we will propose a new concept of science, unifying it with philosophy.
1- The objective of Science
Science has truth as its only objective. This objective is essential to any tentative of classification in science.
2- Basic Postulates of Science.
2.1- Compatibility with the Facts
The Truth in science can be defined as “all information compatible with reality”. The term “compatible with reality”, in our definition of truth, must be understood as “according to the facts”, never in contradiction to them. This way, “compatibility with the facts” provides the empirical feature of science, as it links the scientific truth to the reality of the facts.
2.2 – The Universe is Logical
Likewise, we must also take the fact that our universe is logical as a scientific postulate. That is, the universe – defined as the set of all that exists – does not present logical contradictions between its element and laws. It must, therefore, follow the classical logic (aristotelic). Such an assumption is important because no illogical events have ever been verified in the universe. Secondly, if contradiction was allowed, science would be “trivialized”, that is, every kind of affirmation would be true, even if it was absurd, since a logical system with incompatible premises necessarily implies that any proposition is true. In the appendix ‘A’, at the end of this text, we prove that the proposition “the universe does not exist” can be logically derived from a logical system that presents contradictory premises. Some usual definitions of science can be found in the appendix ‘B’.
3- The scientific method
The set of rules with which science seeks knowledge (information considered ‘true’ or highly reliable) is what we usually call “Scientific Method”.
3.1-"The Deductive Method"
The deductive method comes from the assumption that the universe is logical, so the logical inferences can be applied to scientific theories in order to extract other theories which, by logical consequence, should also have the same degree of reliability. The basis of the deductive method is the logical syllogism known as "modus ponens" [8]:
H => D (If "H" implies "D")
H (and "H" happens, i.e. H is true)
=> D (We can conclude that "D" will also happen)
This rule can be summarized in the following tautological formula:
((H => D) ^ H) => D
(If "H" implies "D" and "H" happens, we can conclude "D").
Example: "If all geese are white" and my aunt has a goose, I can conclude that it is white. Thus, from the general theory H: "all geese are white", we can extract the particular theory D, "my aunt’s goose is white."
3.2-"The Hypothetical Deductive Method"
One of the most important rules of the scientific method, "The Hypothetical-Deductive Method" is based on the logical tautology known as "Modus Tollens" [7]:
~ D (and "D" does not happen, i.e. D is false)
=> H ~ (We can conclude that "H" did not happen)
And it can be summarized in the following formula:
((H => D) ^ (~ D)) => ~ H
(If "H" implies "D" and "D" did not happen, we can conclude that "H" did not happen).
Which can be interpreted as follows: "If 'H' implies 'D', and 'D' is false, we can conclude that 'H' is false."
As an example: If "all geese are white", it implies that my aunt’s goose should be white, but, in fact, my aunt has a red goose, so I can conclude that 'all geese are white' is a false theory.
Thus, in order to investigate a theory "H" under the conditions in which this theory implies the consequence "D" , if this consequence is not verified, that is, if the conditions where H is true the consequence "D" is not true, we can conclude, logically, that the theory "H" is not true (it is refuted). This is an important result since it becomes unnecessary to investigate directly theory "H"; investigating its consequences ("D") to conclude about "H" should be enough. Of course, if "D" is observed we cannot conclude that "H" is correct, but "H" will be “stronger”, that is, with a higher degree of reliability, having passed the test.
It is important to note that the scientific methodology comes directly from the postulate that the universe behaves logically. If it were not so, neither the hypothetical-deductive nor the deductive method could be justified.
The "Inductive Method", or simply induction, is not strictly considered part of the scientific methodology, as it goes from particular events, or samples, to derive general theories. Thus, we can never claim that what came from an induction is true simply because it came from an induction. For example: "All geese I have seen in my life are white, then, can I conclude that all geese are white?" We cannot. "The sun comes out every day since mankind exists. Can I conclude that this will happen forever? "We also cannot.
Nevertheless, we cannot put the "inductive method" in the ostracism because, although not very reliable, it provides us with important clues to connect our mind to reality. No scientific theory would have been discovered without induction. What are the scientific observation and the empiricism if not an inductive method to get to hypotheses of a general nature?
If we do not understand the "inductive method" as a criterion for evidence of scientific theories, but as a method to provide hypotheses for theories or ideas, it can be considered valid and very precious. Isaac Newton, for example, would not have discovered the law of gravity if he had not seen the attraction of matter. Einstein would not have created General Relativity if there were not experiments showing that the speed of light was constant.
4-The Origin of Scientific Theories
It is important to note that science does not make any restriction on the origin of scientific hypotheses or theories. [We will consider, in this text, hypotheses and theories as synonyms. In general, a theory begins as a hypothesis, and after several tests, if it manages to pass unscathed, it receives the ‘status’ of scientific theory. However, a 'brand new' hypothesis can be true while a very old theory can be false (do you remember the theory about the Earth being the center of the universe?). This way, with all the logical and scientific rigour, a theory is not necessarily more valid than a hypothesis. New theories can be achieved through induction (which is the most used method), but they can also be achieved through pure imagination, or even dreams [9]. There are no restrictions to create hypothesis. The theories are not refuted by looking at their origins, but at their consequences.
5-Pseudo-Sciences
There are no restrictions about the origin of scientific hypotheses. A priori, No hypothesis or theory can be discarded only because it was produced from induction or empirical observations. Although this scientific freedom of creating hypotheses can be enriching, since no one is prohibited from creating new and revolutionary scientific theories, it causes, in a terrible contrast, abundance of illogical and absurd theories and hypotheses that reclaim the status of scientific theory: they are the famous "pseudo-sciences."
6-Popper and the Falsifiability Criterion
The postulates and scientific methods described herein are adopted, if not explicitly, at least implicitly, by nearly all scientists and philosophers in science. However, they are yet not sufficient to accurately delimit what is scientific and what is not, or to separate science from pseudo-science.
We will take, as an illustrative example, the "Green Imp Theory" (GIT): "There is always a 'green devil' hovering over each person’s shoulder, but whenever someone tries to look at it, or makes any attempt to detect it or record it somehow, it will get invisible and undetectable. " This example proposes a theory that does not go against any scientific postulate and is not inherently inconsistent, what could be enough reason to reject it, but nevertheless, we are unable to test this theory. So what do we do?
The first philosopher who tried to clearly demarcate what is science and what is not was Karl Popper (7/28/1902-9/17/1994) [1]. Popper delimited science by adding the following criteria to it [10]:
1-No scientific theory can be proved true.
2-A scientific theory can only be proved false.
3-A theory which cannot be refuted is not a scientific theory.
Thus, with this new set of postulates, Popper introduced the 'falsifiability' (or ‘refutability’) as the main criterion of distinction between scientific and unscientific theories. The ‘refutability’ of a theory means that, in principle, the theory is liable to be distorted and thus be or not refuted (Modus-Tollens would be a way to refute a theory). For example, when analyzing the case of our ‘Green Imp Theory (GIT) above, we now realize it is not a scientific theory, since it is a theory that cannot be distorted neither directly or indirectly; therefore, it is not refutable and cannot be a scientific theory.
It is important to reinforce the idea that there is no "confirmation" of a scientific theory. If a theory passes the tests, it is said that the theory was corroborated by the tests; never confirmed by them (in the sense that it has been proved true). When a theory is corroborated, it only gains reliability, because by the criterion (1) above, no theory can be considered true:
"The science method consists of daring ingenious conjectures followed by rigorous attempts to falsify them." Only the aptest theories survive. It is impossible to legitimately say that a theory is true; one can say with optimism that it is the best available, better than the ones that already exist "[3]
In spite of the “popperian” ingenuity about delimiting science, the criticism was abundant.
6.1-Critique and Defenses on the 'Popperian Falcificacionism'
The main criticism to the "Popperian falsificationism" is that the tested theory is always inside an environment which conditions cannot always be fully controlled or evaluated. Thus, there can be a "false negative" in relation to its validation, and the theory can be prematurely discarded. For example, suppose we want to test the theory "All geese are white" and for that, we try to refute it by observing with binoculars, cameras and other observation paraphernalia, several geese spread over the world. Finally, an observer is able to shoot from far away, a brown goose flying along with his flock of white geese. Now that he has this evidence, it is possible for him to refute the theory. But what if the goose was only dirty with earth? Would we be prematurely dismissing a true theory?
This critique to the "Popperian falsificationism” is valid; however, it can be easily refuted with the following argument: if this theory was unfairly distorted by a misled or even fraudulent observation, this observation did not really act as a refutation of the theory. A false refutation is not a refutation. Likewise, we cannot invalidate the justice system simply because someone can present false evidence to condemn or acquit a defendant. If the rebuttal example is not valid, and the theory is unfairly rejected, this, as a single element, does not diminish the merit of the falsificationist criterion; it only states that we must be very careful with the tests and, moreover, it will always be possible to try to refute your own rebuttal. That being done, the theory can be "reborn" and reconsidered valid. If not, it should remain in the limbo of refuted theories waiting for a possible counter-rebuttal that might come in the future, if ever.
A second type of criticism, also widely used, is that "falsificationism" does not follow what the history of science has shown. If we analyze the evolution of science from its historical development, we will not find the rationality that Popper tries to impose to it. But this critique does not make any rational sense, because this would be like saying we should not create remedies in laboratories because if we study human evolution, mankind has always survived and evolved without any medicine. It is not rational to claim that we should keep a certain modus operandi simply because in the past it has always been so. However, despite the criticism to Popper is subject to refutation, there is in fact, as we will see next, a logical inconsistency in the “Popperian” criteria. And that is fatal to science and also to the "popperianism".
6.2 Refuting Popper
Although the historical criticism to the popperian “falsificationism" is refutable, since they do not really affect the falsificationist process logic, the postulates introduced by Popper are actually inconsistent. And the internal inconsistency in science is simply fatal. In order to prove that, we will consider the first two criteria proposed by Popper to demarcate a scientific theory:
i) No scientific theory can be proved true (confirmed).
ii) A scientific theory can only be proved false.
Taking the basic postulate that science seeks truth and not necessarily the usefulness in the theories, even because the "usefulness" of a theory is subjective, we should take the postulate (i) not as a condition for a theory to be scientific, but as an impossibility of proving it true.
If we interpreted the postulate (i) as a condition for a theory to be scientific, many theories that could be proved true would be considered anti-scientific in spite of science seeking the truth! That would be a complete nonsense. Therefore, we must interpret the postulate (i) not as a condition to which theories must obey to be considered scientific, but as an impossibility of being sure of what the ultimate essence of reality is. We cannot, for example, even prove that solipsism [14] is false: any information that reaches our consciousness could be only an imagination of a reality that actually does not exist. Could anyone, for example, prove we are not dreaming?
We do not need, however, to reach the limits of epistemology to understand why we cannot be absolutely sure of the veracity of a scientific theory: It is impossible to know whether we have, in fact, knowledge of every possible condition that influences the applicability of a theory. Without making these conditions explicit, the theory may not be valid in certain contexts in which the conditions cannot be verified. As an example, consider the theory "water boils at 100 degrees Celsius." This theory is valid only under conditions of adequate pressure (1 atm), otherwise it is false. Thus, a more correct theory would be: "Water boils at 100 degrees Celsius at 1 atm pressure." Do we have now all the necessary conditions? What if water is composed mostly of heavy hydrogen atoms (deuterium)?
Let us now change focus and show the inconsistency of the criteria (i) and (ii):
Consider the following theory: "This shoe box contains a frog."
This theory is not very useful but, for now, we are not concerned about the usefulness of theories, we are concerned about its veracity. If we open the shoes box and find a frog, what can we say? Can we consider the theory true? Would that refute Popper’s postulate (i)? These matters are not trivial, since it is possible to say that what we see is not a frog but a toad, or that it could be an optical illusion or even a dream and therefore, we cannot claim that the box contains a frog or that the box exists. Indeed, these philosophical claims can keep the criterion (i) unharmed; however it contradicts the rule (ii) "A scientific theory can only be proved false”. If not, see:
If a theory can be proven false, then it is also true that its contradiction can be proven true.
At the very same time a theory is proved false, the theory that denies it is being proved true. Here, the sense of the word "prove" has the same connotation as to prove a theory false or true. As an illustration, consider, for example, theory A: "All geese are white." If we can prove this theory false by presenting, for example, a red goose, we will be at the same time proving that theory B "Not all geese are white" is true!
However, if we philosophically accept the fact (i) to be true, that is, if we admit that we cannot be sure about the ultimate truth of reality, then, strictly speaking, we can never say that a theory can be proved false, because if a theory "T" can be proved false, the opposite theory "Non-T" (denial of "T") can be proved true, that is, we would have the theory "Non-T" as an absolute truth . Anyhow, we conclude that the "Popperian falsificationism" is intrinsically contradictory, and that makes it easier for a new theory about science to be elaborated.
continue...
((H => D) ^ H) => D
5-Pseudo-Sciences
6.2 Refuting Popper
continue...
