Expectation for the Harmonic Oscillator ( using dirac)
5 replies · 2K views · last reply
Somali_Physicist
I've been trying to form a proof using , using majorly dirac notation.There has been claims that its much better to use in QM.
The question i wanted to generally show that the expected value is Zero for all odd energy levels.I believe i have solved the question but I am a bit Iffy about a step i took:
<x>n = <Ψn|x|Ψn> = L
for a given Ψn = (A+)n(n!)-2
Energy eigen functions have definite parity, assume for all odd n's if one is zero the rest should follow.
Take n = 1
=> L = <(A+)(n!)-2|x|(A+)(n!)-2>
= (n!)-1 <(A+)|x|(A+)>
B = <(A+)|x|(A+)>
Define A+ = Lx + iC : B,C are Real
=> <Lx+iC|x|Lx+iC>
(Bit iffy after these steps)
= <Lx|x|Lx|> + <iC|x|iC>
= <L|x3|L>+<C|x|C>
as ∫x2n+1dx for limits [-∞,∞] and n =0,1,2,3...
=> 0
we find B=0
therefore
<x>n = 0
For odd ns.
What about even values of ##n##? You are going about it backwards. Instead of replacing ##\psi_n##, write operator ##x## in terms of ##a^{\dagger}## and ##a## and use your knowledge of what ##a^{\dagger}|\psi_n>## and ##a|\psi_n>## are equal to.
Surely you wouldn't get an actual value for even values.That would be extremely counter intuitive, that said I will try your advice.
You wrote a couple of things that don't make sense.
Somali_Physicist said:
Ψn = (A+)n(n!)-2
This should be
|\psi_n\rangle = \frac{(A^\dagger)^n}{\sqrt{n!}} | 0 \rangle
The notation here doesn't work. You can't have an operator in a bra or a ket. You should end up with something like
\langle 0 | A x A^\dagger |0 \rangle
and so on.
Why is it so counter intuitive? In your proof, which needs fixing as @DrClaude suggested, you have the integral ∫x2n+1dx where n is odd. What would happen to this integral if n were even? Say n = 2k?
What do you mean by "energy", i.e. what is the Hamiltonian?
