How Do OS and NS Drumming Techniques Differ in Terms of Physics?
  • Thread starter Thread starter Sko
    Physics
The discussion contrasts Old School (OS) and New School (NS) drumming techniques, emphasizing that OS techniques are more grounded in physics. OS drummers position their fulcrum closer to the center of gravity, allowing for quicker stick control due to lower rotational inertia compared to NS drummers. The types of drum heads, kevlar and mylar, are analyzed for their sound production capabilities, with mylar heads likely producing brighter sounds due to their flexibility. The conversation also touches on the vibration modes of drumsticks and how they affect sound clarity and frequency, noting that denser materials tend to vibrate at lower frequencies. Overall, the physics of drumming techniques and materials significantly influence sound quality and control.
Sko
In drumming there are 2 conflicting points of view-New School (1980's to present; referred to as NS from now on) and fading Old School (dominated 1960's-1970's; referred to as OS). OS's techniques are generally more founded in physics.
I'm going to go through some of the physics in drumming 1 issue at a time and was hoping for some of the more knowledgeable to eloborate/correct...
The OS place their fulcrum (thumb and forefinger) about an inch from the CG, and NS place their's usually about 2 inches from the end. Since rotational inertia (tendency of an object to resist change in its rotational state of motion) for an object rotating about its CG (OS style) is I=\frac{1}{12}mL^2 and I=\frac{1}{3}mL^2 for a object rotating about its end, OS'ers will be able to start and stop their stick faster than NS'ers (more control).
Ok, now I have a question for you...
There are 2 main types of drum heads, kevlar and mylar. Kevlar is very stiff (used in bulletproof vests) and mylar is more flexible (used in weather ballons). Which can produce more variation in magnitude of sound (haven't done this in physics yet maybe not the right term)? If it's possible to explain which can produce clearer notes?
Re your second post, more compliant material allows higher frequencies, so I'm guessing the mylar heads will give a brighter sound.
Re your first post, you are leaving out some of the physics. The drumstick itself has vibration modes too. The NS technique places the fulcrum nearer the node, allowing the drumstick to vibrate more freely. My guess is that although this is nice when drumming close to the stick's natural frequency, it impedes other beat rates.
Density of the drum head is only one of the parameters which would effect the frequency of vibration. A drumhead can vibrate in many different modes. The mode of vibration determines the frequency and amplitud of the vibrations. Other factors are tension, how the head is fastened, area of the head and even where and how hard you strike the head.
Given equality in all other factors I believe that the denser material will vibrate at lower frequencies.
I would interpret "Clearer notes" to mean fewer harmonics. This is a hard one to call. More harmonics are generatated when greater forces are involved.
I am not sure how "Stiffness" enters into the equations, that would be different from density, perhaps someone else can add something.
I'm assuming stiffness would increase the force exerted on the head and the stick, but cut down on vibrations.
Here's a link that talks more about each type of head, though not in physics terms. http://www.drumdojo.com/kit/heads.htm
Also ever heard of moment of inertia and how it would relate to drumming?
Moment of intertia has to do with thing rotating, your drum stick has a moment of inertia that effects how it spins. Not sure that has anything to do with drumming, only the visual effects! :smile:
http://users3.ev1.net/~rbeckham/m1.jpg
Heres an article that talks about it I am not sure I understand it tho...
