Experiment with angular acceleration
The discussion centers on determining the best estimation of angular acceleration from an experiment involving a rotating cylinder and a dropping weight. The experimenter has calculated an average angular acceleration weighted by uncertainties but is unsure how to quantify the uncertainty of this average. They seek clarification on the correct method for calculating the uncertainty associated with the estimated angular acceleration. The conversation references the concept of mean squared error as a potential approach to address this uncertainty. Understanding how to properly calculate and interpret these uncertainties is crucial for accurate results in classical mechanics experiments.
aaaa202
I'm not sure if this goes in there since it's a question about an experiment involving classical mechanics.
So I've done an experiment where I have determined for a rotating cylinder, its angular acceleration as I let a weight attached to it drop. Now each of these angular accelerations have an uncertainty, and I want to figure out the best estimation for the angular acceleration. What I did was to make an average over the angular acceleration weighted over their uncertainties. This is correct right? - I'm pretty sure, that's how it's done.
My problem is however, that I now don't know how to figure out the uncertainty for this estimated angular acceleration - how do I do that?
After this, I don't know what your explanation(s) means.
one approach:
http://en.wikipedia.org/wiki/Mean_squared_error
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
