Experimental Data: Light Velocity Change
This discussion centers on the effects of acceleration on the perception of time and distance in the context of special relativity, specifically regarding a scenario where an observer accelerates towards a clock that is initially 10 light seconds away. The observer experiences length contraction, calculated using a Lorentz factor (gamma) of 2, resulting in a perceived distance reduction. The calculations reveal that while the stationary observer measures a time of approximately 74.666 seconds for the light to reach the observer, the accelerated observer perceives the time to be 20 seconds due to time dilation and the relativity of simultaneity. The discussion emphasizes the complexities of visual perception of time in relativistic frames.
  • Understanding of special relativity concepts, including time dilation and length contraction.
  • Familiarity with Lorentz transformations and the Lorentz factor (gamma).
  • Basic knowledge of the speed of light as a constant in all inertial frames.
  • Ability to perform calculations involving relative velocities and distances in a relativistic context.
  • Study the implications of the Lorentz factor in various relativistic scenarios.
  • Explore the concept of simultaneity in special relativity and its effects on observers in different frames.
  • Investigate experimental evidence supporting time dilation and length contraction, such as the Hafele-Keating experiment.
  • Learn about the Doppler effect in relativistic contexts and how it affects the perception of light signals.
Physicists, students of relativity, and anyone interested in the implications of acceleration on time perception and distance measurement in relativistic physics.
Wizardsblade
Are there any experiments that show how light is treated as a frames velocity is changed (not the light source, rather the "eye".) For example if a huge clock that is counting down from 10 is 10 light seconds away before I accelerate (at t=0) to a velocity where my length contraction is *.5 (I think that is gamma = 2?) How long will it be before I see the clock reach 0? If I had not accelerated it would have taken 10 seconds. (As a side note the large clock has counted down to 0 simultaneously with my t=0, just the distance delays the signal 10s in the original rest frame.) Once I have accelerated would it still take 10 seconds to travel to me or since there is length contraction would it only take 5 seconds now? or perhaps something else?
from your point of view the distance between you and the clock has shrunk by half but the clock is also ticking half as fast. also there is a shift in simultaneity that occurs whenever one accelerates that complicates things.
it would be easier to calculate it from the point of view of a stationary observer. from their point of view the length contraction only affects you and is irrelevant. once you determine how much time the stationary observer measures then its trivial to convert to your time. v=0.75^0.5
btw, you didnt state whether you are moving toward or away from the clock.
Because the speed of light is constant in all frames I do not think it matters what direction you are moving in. Once you have accelerated there is no difference between you moving toward/away from the clock or the clock moving toward/away from you (besides doppler effect but that is not what this question is about.)
What I am trying to find out is what happens when one accelerates as far as length contraction/time dilation, and what experimental evidence there is as support. Specifically in situations such as the one above.
How long will it be before I see the clock reach 0? do you mean 'see' the clock reach 0 or do you mean 'calculate' that the clock reaches 0 (taking time of flight for the photons into account)?
Actually “see”. Then calculate =)
Hi Wizardsblade,
Assuming you are moving away from the big clock:
At gamma =2 your velocity is v=sqrt(0.75) = 0.866c as stated by granpa.
When you see the big clock read 10 seconds you know the clock has reached zero locally so you accelerate at that instant. To an observer at rest with the big clock the distance the light travels to catch up with you is d=c*t seconds. This is the same as the distance you have traveled in the same time, plus your head start of 10 light seconds, so the unaccelerated observer can also say d=(v*t+10). Equating the two expressions for distance we get c*t = v*t+10. From that it is easy to work out that the time t = 10/(c-v) = 10/(1-0.866) = 74.666 seconds as measured by the non accelerated observer. The time according to you is t/2=37.333 seconds due to time dilation.
Assuming instantaneous acceleration as soon as you switch frames from stationary to 0.866c you see an offset of -17.333 seconds on the big clock due the relativity of simultaneity so you calculate the big clock does not reach zero until 17.333 seconds after you accelerate and visual signal arrives at 37.333 seconds after you accelerated, giving a total elapsed time of 20 seconds by your calculations.
Thanks guys. Does length contraction not play a part?
  • · Replies 42 ·
  • · Replies 38 ·
  • · Replies 54 ·
  • · Replies 28 ·
  • · Replies 88 ·
  • · Replies 16 ·
