Explanation of sequential circuit
A sequential circuit integrates combinational circuits with memory elements, creating a feedback loop that defines its state based on stored binary information. The next state of the circuit is influenced by external inputs and the current state. Synchronous sequential circuits operate based on signals at discrete time intervals, while asynchronous circuits react to input changes at any moment. Flip-flops, which store one bit of information, are the primary storage elements in synchronous circuits. The complete behavior of a sequential circuit can be represented by a truth table that correlates previous states and current inputs.
asiitew
Sequential circuit is a circuit which contains combinational circuit in addition to memory elements.Memory elements form a feedback path.The binary information stored in the storage elements at any given time defines the state of the sequential circuit at that time.The next state of the storage elements are determined by the external input and present state.A synchronous sequential circuit is a system whose behaviour can be defined from the knowledge of its signals at discrete instants of time.The behaviour of asynchronous sequential circuit depends on the input signals at any instants of time and the order in which the inputs change.The storage elements used in synchronous sequential circuit are called flip-flof.A flip-flop stores one bit of information.
is there a question in this?
it appears that what you have written is accurate. you might want to put in the fact that the sequential circuit (also called a state machine) is fully defined by the truth table that defines the new state as a function of the previous state and the current input values. of course, that truth table can be expressed as a set of boolean equations (and you want the truth table to be sparse).
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 31 ·
