Explicit Formula for Sum of Series
The discussion revolves around finding an explicit formula for the sum of the first n terms of the harmonic series: 1, 1/2, 1/3, 1/4, 1/5. Participants note that there is no simple formula for this series, unlike arithmetic or geometric series. The sum can be expressed as S_n = ∑(1/k) from k=1 to n, but deriving a straightforward formula for the numerator remains challenging. Some suggest that the denominator is the least common multiple (LCM) of the integers from 1 to n, while the numerator is more complex. Ultimately, the consensus is that an elementary formula for the nth partial sum does not exist.
Andy111
Determine an explicit formula for the sum of n terms for the given series:
1, \frac{1}{2}, \frac{1}{3}, \frac{1}{4}, \frac{1}{5}
I calculated the first 5 terms for the sum sequence and got:
1, \frac{3}{2}, \frac{11}{6}, \frac{25}{12}, \frac{137}{60}
but I can't find a pattern to determine an explicit formula.
Maybe I'm misunderstanding your question, but wouldn't it just be \sum_{n=1}^\infty 1/n ?
The question asks for n terms, not an infinite number of terms
Oh, sorry. I read the original post too quickly.
That's alright, nothing to bash heads in about! As for the problem, it's a doozy...
You're right, it is a doozy! This series is known as a harmonic series, and according to http://plus.maths.org/issue12/features/harmonic/index.html" , "there is no simple formula, akin to the formulae for the sums of arithmetic and geometric series, for the sum."
Well then wouldn't it just be:
\sum_{k=1}^n \frac{1}{k}
S_1=1
S_2=1+\frac{1}{2}=\frac{2+1}{2}
S_3=1+\frac{1}{2}+\frac{1}{3}=\frac{6+3+2}{6}
S_4=1+\frac{1}{2}+\frac{1}{3}+\frac{1}{4}=\frac{12+6+4+3}{12}
blah, that doesn't actually seem to work!
I know! It's whack!
I started out trying to find formulas for numerator and denominator separately. In cases where it doesn't simplify, the denominator is n! . As for the numerator, aside from the obvious (n! + n!/2 + n!/3+...+n!/n) I do not see how to arrive at a formula.
According to http://mathworld.wolfram.com/HarmonicSeries.html you can write it as a sum of the Euler-Mascheroni constant and a digamma function. I'm guessing if there were an easier expression they would have mentioned it. I think steelphantom is right, there is no elementary formula.
I think all it is is sigma from k=2 to n of 1/n. very simple that would start off with one half then one third then one quarter and so on.
That much is obvious. The trouble is finding a formula for the nth partial sum.
I think it's impossible, infinity would be the common denominator.
Not for the sum of n (a finite number) terms.
The denominator ought to be the lcm(1,2,...,n) whereas the numerator is the puzzle.
