Why is the operator <p> considered real in calculus?
  • Thread starter Thread starter chingcx
chingcx
<p> is the integral of the product of a real function and its first derivative, multiplied by an imaginary number. But why <p> is real?
If the wavefunction is purely real, then <p> = 0:
\langle p \rangle = \int_{-\infty}^{\infty} \psi^* \left(-i\hbar \frac{d\psi}{dx} \right) \; dx
If \psi^* = \psi, then this can be written
\langle p \rangle = -i\hbar \left. \int_{-\infty}^{\infty} \psi \frac{d\psi}{dx} \; dx = -i\hbar \psi(x) \right|_{-\infty}^{\infty} = 0
where we have used the boundary condition that the wavefunction must vanish as x \to \pm \infty. On the other hand, if we can write
\psi(x) = e^{ikx} R(x)
where R(x) is real, then
\langle p \rangle = \int_{-\infty}^{\infty} \psi^* \left(-i\hbar \frac{d\psi}{dx} \right) \; dx = -i\hbar \int_{-\infty}^{\infty} \left( e^{-ikx} R(x) (ik) e^{ikx} R(x) + e^{-ikx} R(x) e^{ikx} \frac{dR}{dx} \right) \; dx = \hbar k \int_{-\infty}^{\infty} R(x)^2 \; dx = \hbar k
So, to have a nonzero momentum, the wavefunction needs a phase that varies with x.
Because of hermitian conjugate
If \hat{p} is selfadjoint, then its expectation value in any state is real.
As in the last two posts, the most elegant and general way to see that <p> comes from the fact that p is a hermitian operator.
But if you only know about p in position space (i.e. p = -ih d/dx) then you can see that <p> is real by showing that <p> = <p>* (is this statement obvious?).
Do this by starting with the first equation in Ben Niehoff's post. Take the complex conjugate of both sides, i's become -i's, and psi -> psi* and psi* -> psi. Then with some manipulations (including an integration by parts) you can show that this expression is identical to the formula you started with, so <p>*=<p>.
Hope that helps a little.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
