Exponential form of a complex number
To find the exponential form of the complex number z = -2 + 2i, the correct values for r and θ must be determined. The modulus r is calculated as r = sqrt(a^2 + b^2), which gives r = sqrt(8). The angle θ is found using θ = tan^-1(b/a), but since z is in the second quadrant, the correct angle is θ = 3π/4, not -π/4. This highlights the importance of considering the signs of a and b to determine the correct quadrant for θ. Understanding the multi-valued nature of the tangent function is crucial for accurately finding the angle in complex numbers.
blues1
if z = -2 + 2i
find r and θ
our teacher told us that when we have z = a + bi
r = sqrt(a^2 + b^2)
and θ = tan^-1(b/a)
so here it's supposed to be r = sqrt(8) and θ = - pi/4
but using wolfram alpha to see if the results are matching I get that
sqrt(8)*e^(i*-pi/4) is 2 - 2i
what am I doing wrong? I guess this has to do with the θ, but since it's always tan^-1(b/a) why am I getting different results?
This is an example of why you should not use formulas without thinking.
b/a and therefore tan(b/a) are exactly the same if you change signs on both a and b. In particular,
\frac{-2}{2}= \frac{2}{-2}= -1
Also, tan(\theta)= tan(\pi+ \theta). Since tan is "multi-valued", a calculator or computer (or table of trig functions) will get the principle value which is always between -\pi/2 and \pi/2. To distinguish between the two you need to look at the signs of the individual numbers. (-2, 2) is in the second quadrant so \theta is between \pi/2 and \pi. In this problem, \theta= \pi- \pi/4= 3\pi/4, NOT -\pi/4.
if i remember correct everything is positive from 0 to pi/2, in pi/2 to p only the sin is positive, cos is positive from p to 3pi/2
so if I get a negative θ and z for example is from 0 to pi/2 I should just have tan^-1(b/a)
if I am from pi/2 to p, I should have p - tan^-1(b/a)
from p to 3pi/2 => 3pi/2 - tan^-1(b/a)?
is this how it goes? :/
I don't understand what you are saying. If z = a + bi and both a and b are positive, θ = tan^-1(b/a) would just be positive.
No. If z = a + bi and both a and b are negative, then when you find tan^-1(b/a) you will get an angle between 0 and π/2. But you want to be in Quadrant III, so you'll have to add pi.
And you're missing the case of z being in Quadrant IV of the complex coordinate plane.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 22 ·
