Exponents and exponential functions
4 replies · 6K views · last reply
carbz
Please note, there are more questions than what I'm going to give, in total I'll be giving 3. I hope to use the information with the others.
1)
Solve the equation:
[tex]5^{1-2x} = \frac{1}{5}[/tex]
None
I was thinking that to make live easier, to put the entire fraction up to the first power. From there, I would use algebra in the sense of:
[tex]1-2x=1[/tex]
[tex]-2x=0[/tex]
To get x = 0. But, that doesn't seem to be possible, since the exponent must turn out to be negative.
2)
Solve the Equation:
[tex]8^{x^{2} - 2x}} = \frac{1}{2}[/tex]
None
For this one, I was thinking of setting the fraction equal to 1, then factoring that out to get two answers:
[tex]x^2 - 2x = 1[/tex] [tex]x^2 - 2x - 1 = 0[/tex]
But, then I'm stuck there.
3)
Solve the equation:
[tex]e^{x^2} = (e^{3x})(\frac{1}{e^2})[/tex]
None
I'm completely clueless on this one.
1)
Solve the equation:
None
Actually a very relevant equation, or, more correctly, statement, would be "if ax= ay then x= y" (the exponential functions are "one-to-one").
[tex]1-2x=1[/tex]
[tex]-2x=0[/tex]
[itex]\frac{1}{5}= 5^{-1}[/itex] not 51
2)
Solve the Equation:
None
8= 23 so [itex]8^{x^2- 2x}= 2^{3(x^2- 2x)}[/itex]
3)
Solve the equation:
None
Learn the "laws of exponents": (ax)y= axy (used in 2 above) and axay[/sup]= ax+y.
Here, [itex]e^{3x}(\frac{1}{e^2}= (e^{3x})(e^{-x})= e^{3x-x}= e^{2x}[/itex]. Your equation is [itex]e^{x^2}= e^{x}[/itex] so x2= x.
All right. For the first one, I see where you went from there. I got the answer to that to be [tex]x=1[/tex].
Ok, so with the exponents, that would be [tex]3(x^2 - 2x) = 1[/tex]. Then, factoring out an x would make it: 3x(x-2) =1 . Dividing it would cause the equation to look like: [tex]x-2 = \frac{1}{3x}[/tex] Then [tex]-2 = \frac{-2}{3x}[/tex] then [tex]-6x = -2[/tex] then finally I get [tex]x = \frac{1}{3}[/tex]. Is that correct?
HallsofIvy said:
Learn the "laws of exponents": (ax)y= axy (used in 2 above) and axay= ax+y.
Ok, since that is so, the answer could only be either 0 or 1, since both when squared equal what it orginally was.
[tex]\frac{1}{2}=2^{-1}[/tex] not 21
This is a quadratic equation, and so will have two solutions. In solving it, you should put the equation in the familliar form, and use the quadratic formula:
[tex]x=\frac{-b\pm \sqrt{b^2-4ac}}{2a}[/tex]. In particular, you cannot divide by x, since you do not know it's value (it could be zero.)
Actually, I think HallsofIvy carried a typo through the below calculation:
Here, [itex]e^{3x}(\frac{1}{e^2})= (e^{3x})(e^{-x})= e^{3x-x}= e^{2x}[/itex]. Your equation is [itex]e^{x^2}= e^{x}[/itex] so x2= x.
It should read:
[tex]e^{3x}(\frac{1}{e^2})= (e^{3x})(e^{-2})= e^{3x-2}[/tex] which gives your equation [itex]e^{x^2}=e^{3x-2}[/itex] giving [itex]x^2=3x-2[/itex]. This can again be solved as a quadratic equation.
How did you manage to go from [itex]x-2= \frac{1}{3x}[itex]to [itex]-2= \frac{-2}{3x}[/itex]? [itex]3(x^2- 2x)= 1[/itex] is a quadratic equation, as Cristo says. In "standard form" it is [itex]3x^2- 6x- 1= 0[/itex].<br /> <br /> <br /> <br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Ok, since that is so, the answer could only be either 0 or 1, since both when squared equal what it orginally was. </div> </div> </blockquote> Unfortunately, as Cristo said, I misread [itex]\frac{1}{e^2}[/itex] as [itex]\frac{1}{e^{2x}}[itex]. Check what he wrote.[/itex][/itex][/itex][/itex]
