Expressing complex numbers in the x + iy form
To express the complex number ((1-i)/(sqrt2))^42 in x + iy form, first identify the modulus and argument, yielding r = sqrt2 and an angle of 7pi/4. The expression can be simplified using the formula for powers of complex numbers, specifically (r e^(iθ))^n = r^n e^(i nθ). After applying this, the result becomes (sqrt2)^42 e^(-i(147pi/2)). The final step involves converting the exponential form back to x + iy using Euler's formula, which relates complex exponentials to sine and cosine functions. This approach allows for a clear calculation without prematurely converting to a + bi form.
Logan Land
((1-i)/(sqrt2))^42
express in x+iy form
z1/z1=(r1/r2)e^(i(theta1-theta2))
Ive found that (1-i) has r=sqrt2 so since r is sqrt2 and x=1 y=-1 so the angle is 7pi/4
so then I have (sqrt2e^(-i7pi/4)/sqrt2)^42
now from here is where I don't understand where to go to obtain x+iy form since it is raised to the 42 power and I don't have a e on the bottom
Don't change the result back to a + bi form until you have finished raising it to the 42 power. Use the formula for (r e^{i \theta})^n = ....
that formula isn't in my book
It works just like the formula for (ab^k)^n = ... works for real numbers a,b,k, and integer n.
so then ((sqrt2)e^(-i7pi/4))/sqrt2)^42
= 1/e^147ipi/2 ?? doesn't seem like that's correct
You didn't make a correct application of (ab^k)^n = a^n b^{kn} For one thing, you didn't raise a = \sqrt{2} to a power.
Maybe it doesn't seem correct to you, but you really did it right according to me !
(I was wondering why you didn't let the factors sqrt(2) cancel straightaway. Matter of obfuscating notation ?)
$${1-i\over \sqrt 2} = e^{{7\over 4}\pi}$$
Draw a unit circle, consider the x-axis the real axis and the y-axis the imaginary axis, and mark your ## {1-i\over \sqrt 2}##
You should see the ##{7\over 4}\pi## (with a plus sign ! *) , the de Moivre thing, and lots more goodies. Play with squaring the number, etc.*) check where ##e^{-{7\over 4}\pi}## is located on that unit circle !
