Fabricate uniform wire out of 2.1g of copper w/ 0.3 ohm resist. - wire diameter?
The discussion focuses on calculating the diameter of a uniform wire made from 2.1 grams of copper with a target resistance of 0.3 ohms. The key equations used include the relationship between mass, density, length, and cross-sectional area, as well as the resistance formula R = ρ_r * (L/A). The correct density of copper is established as 8940 kg/m³, which resolves the initial calculation error. The final diameter of the wire is determined to be approximately 2.1565 mm.
  • Understanding of basic physics concepts such as mass, density, and resistivity.
  • Familiarity with the formulas for resistance and cross-sectional area of a cylinder.
  • Ability to perform unit conversions, particularly between grams and kilograms.
  • Proficiency in using scientific calculators or graphing calculators like the TI-89.
  • Review the principles of electrical resistance and its dependence on material properties.
  • Study the derivation and application of the formula for the cross-sectional area of a cylinder.
  • Learn about the properties of copper, including its density and resistivity, for practical applications.
  • Explore common errors in physics calculations and how to avoid them in problem-solving.
Students in physics or engineering disciplines, particularly those studying electrical properties of materials, and anyone involved in practical applications of wire fabrication and resistance calculations.
student_fun
Suppose you wish to fabricate a uniform wire out of 2.1 grams of copper. If the wire is to have a resistance of 0.3 ohms and if all of the copper is to be used, what must the diameter of this wire (in mm) be?
mass (in kg), cross-sectional area extruded by a length (in m) multiplied by mass density: [tex]m = \rho_{m} \cdot LA[/tex]
Resistance as product of resisitivity and length divided by cross-sectional area: [tex]R = \rho_{r} \cdot \frac{L}{A}[/tex]
Re-written density relation in terms of L to be plugged into resistance equation:[tex]\frac{m}{\rho_{m} A} = L[/tex]
[tex]\rho_{m}: Mass \ density[/tex]
[tex]\rho_{r}: Resistivity[/tex]
Where m is mass in kg, L is length of wire in meters, A is cross-sectional area of wire in m2, R is resistance in ohms, and rho is resistivity in ohm meters.
Use resistance relation with L replaced by re-written form to solve for radius of cross-sectional area. A is replaced by cross-sectional area of a cylinder being pi * r2.
New Equation:
[tex]R = \rho_{r} \cdot \frac{\frac{m}{\rho_{m} \pi r^{2}}}{\pi r^{2}}[/tex]
Plug and chug values from problem (copper density taken to be 8.92 kilograms per meter cubed, resistivity of copper taken to be 1.7E-8 ohm meters, 0.3 ohms is target resistance, and 0.0021 kg from converted 2.1 grams of available copper mass):
[tex]0.3 = \frac{\frac{1.7E-8 * 0.0021}{8.92\pi r^{2}}}{\pi r^{2}}[/tex]
Solving on TI-89 gives 1.0783E-3 which when converted from m to mm gives just 1.0783 as the cross-sectional radius. Then multiplying this by 2 to get final answer of 2.1565 mm is incorrect but close. I am not sure where I messed up. I am sure it must be simple at this point but I am just not seeing it at the moment. Can anyone give me a hint?
I've looked at similar posts and I seem to be on the right track but cannot see my error.
Thank you for your time.
Hi student_fun,
New Equation:
I have not looked too closely at the rest of your post, but this is not right. Water has a density of 1000 kg/m^3, and copper would have a higher density than that. Does fixing this give you the right answer?
ah geeze, thanks for pointing that out. The proper density I should have used was 8940 kg / m3. That solved it. Thanks for pointing out my simple error :) Was up till 2 AM which explains the silly error.
  • · Replies 21 ·
12K
23K
