Factorial Question | Solve k(n-1)! Equation
  • Thread starter Thread starter TheRobsterUK
    Factorial
The discussion centers on interpreting the expression k(n-1)! in the context of factorials. The user, Rob, is trying to determine whether k(n-1)! should be calculated as k multiplied by (n-1)! or if it represents a factorial of a product. He provides an example with k=4 and n=8, calculating both interpretations. The consensus is that k(n-1)! should be understood as k multiplied by (n-1)!, confirming that Rob's initial interpretation is correct. The notation convention used clarifies that k(n-1)! is equivalent to k((n-1)!), avoiding any misunderstanding.
TheRobsterUK
Hi,
I have a question about factorials that I'm hoping someone can help me with.
I know that the factorial n! means the product of the integers from 1 to n, for example if I have 4! then this is equal to 4 x 3 x 2 x 1 = 24, but I have an equation which contains the term:
k(n-1)!
I am not sure how to interpret this...for instance, if we assume that k=4 and n=8, does this give:
4(8-1)!
= 4 x 7!
= 4 x 5,040
= 20,160
Or does it give:
4(8-1)!
=4 x 7!
=28!
=3.0489 x 10^29
I'm guessing it's the first one but am not sure...can someone confirm or provide the correct answer please?
Many Thanks
-Rob
Mathematics news on Phys.org
Note that the notations:
(k(n-1))!, k((n-1)!) CANNOT be misunderstood.
The convention used, in order to save parentheses is:
k(n-1)!=k((n-1)!).
Note that this convention is akin to the one used with expressions involving a power:
A*B^{n}=A*(B^{n})
rather than (A*B)^{n}[/tex]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
