MHB How Does Integer Factorization Impact Modern Cryptography and Beyond?
Integer factorization is crucial for modern cryptography, particularly because it underpins the security of widely used public key systems like RSA. An efficient integer factorization algorithm could compromise these systems, allowing for the rapid computation of the order of multiplicative groups and extending polynomial time algorithms from primes to composites. Beyond cryptography, such an algorithm could also enhance understanding of related problems, including the discrete logarithm problem and prime distribution. While no classical algorithm is known to efficiently factor integers, quantum computing offers potential solutions through Shor's algorithm. The reliance on the difficulty of factorization remains a cornerstone of cryptographic security today.
matqkks
Why is factorization of integers important? What are the real life applications of factorization? Are there are examples which have a real impact.
Mathematics news on Phys.org
If you had an efficient integer factorization algorithm you could do the following:
- efficiently extend all polynomial time algorithms modulo primes to composites via the CRT
- efficiently compute the order of the multiplicative group of integers modulo a composite (thereby breaking the most used public key encryption scheme in the world, namely RSA, and making millions of dollars)
Furthermore there is a good chance such an algorithm could be modified or extended to apply to other important and related classes of problems, such as the discrete logarithm problem, or be used to gain insight into e.g. the distribution of primes. It is unknown if such an algorithm even exists for classical computers, but integer factorization is known to be (theoretically) polynomial time on a sufficiently large quantum computer (Shor's algorithm).
Basically, it is important, because a lot of today's public key cryptography relies on the assumption that factorization is actually hard, an assumption which has been holding very well so far. A fast way to factorize would also have far-reaching consequences beyond this in more theoretical fields, as a lot of problems involving modular arithmetic basically need to factorize their input to work properly, which can be expensive in some cases if the modulus is of unknown provenance (though in many cases it doesn't matter as the modulus has a special form or its factorization is known in advance).
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
