Falling bodies and terminal velocity
The discussion revolves around the behavior of falling bodies, particularly focusing on the effects of mass and air resistance on their rates of fall and terminal velocity. Participants explore the physics behind free fall in a vacuum versus in air, and the implications of terminal velocity on different objects.
  • Some participants propose that two objects of different masses dropped from the same height will fall at the same rate until one reaches terminal velocity.
  • Others argue that the equation of motion, ma = mg - f(v), indicates that air resistance, which depends on factors like size and shape but not mass, affects the fall rate of objects in air.
  • A participant expresses confusion about how mass seems inconsequential in a vacuum but becomes significant when considering terminal velocity, which is influenced by mass, drag coefficient, and surface area.
  • Some participants clarify that heavier objects will fall faster than lighter ones when air resistance is considered, particularly if the objects are of the same size.
  • There is a mention that technically, nothing ever reaches terminal velocity, which adds complexity to the discussion.
  • A historical reference is made to Galileo's demonstration of falling bodies, although it is noted that his findings apply strictly in a vacuum.
Participants do not reach a consensus on the implications of mass in falling bodies, with multiple competing views on how mass and air resistance interact during free fall. The discussion remains unresolved regarding the nuances of these interactions.
Limitations include the dependence on definitions of terminal velocity and air resistance, as well as the unresolved nature of how these factors interplay in real-world scenarios.
CatastrophicF
Is it correct to assume that two objects, with different masses, dropped from the same height at the same time will fall at the same rate until one of the objects reaches its terminal
velocity? What are the applicable equation(s) used to calculate this?
Welcome to PF!
Hi CatastrophicF! Welcome to PF! :smile:
velocity?
nooo …
the equation of motion is ma = mg - f(v),
where f(v) is the function giving the air resistance for that particular body at speed v :wink:
(usually depends on size and shape but not on mass)
nooo …
Thank you for the welcome and response
ma = mg. I understand that equation is essentially telling me that in a vacuum, regardless of mass, two bodies will fall/accelerate at the same rate (on Earth 9.8m/s/s). I think I start to become a little confused once those bodies are falling through a fluid, in this case air. I read and watch videos of people telling me things like the acceleration of gravity is the same on all objects (I'm happy with that) and that intertia is the reason why if I held and dropped a basketball and a bowling ball they would hit the ground at the same time (I'm also happy with that). So my quest to self educate myself in the laws of physics begins with me thinking that mass is a inconsequential property of falling bodies buuuuttttt I also know about terminal velocity, in which mass is a variable. Sooooo my qunadary is as follows; if all bodies accelerate at 9.8m/s/s due to gravity and their terminal velocity is calculated by Cd, surface area and m... why would they not fall at the exact same rate up until the moment one of the objects acheived its terminal velocity?
Hi CatastrophicF! :smile:
CatastrophicF said:
… if all bodies accelerate at 9.8m/s/s due to gravity and their terminal velocity is calculated by Cd, surface area and m... why would they not fall at the exact same rate up until the moment one of the objects acheived its terminal velocity?
because Cd, surface area and m are different (and have different ratios) for different bodies :wink:
(in particular, denser bodies of the same size will have the same air resistance, but more weight, and so will fall faster)
btw, technically, nothing ever reaches terminal velocity! :biggrin:
Look at Tiny Tim's equation in response #3. The drag force is independent of the mass m, so when air drag is present, the mass m no longer cancels from the equation.
So technically speaking a heavier object...will...fall faster than a lighter one. For example if I dropped two bowling balls (same height/same time) that were the same size, one with a mass of 10lbs and one with a mass of 20lbs...the 20lbs bowling ball would, mathematically/physically although maybe not perceivably, fall faster and hit the ground first...?
CatastrophicF said:
So technically speaking a heavier object...will...fall faster than a lighter one. For example if I dropped two bowling balls (same height/same time) that were the same size, one with a mass of 10lbs and one with a mass of 20lbs...the 20lbs bowling ball would, mathematically although maybe not perceivably, fall faster and hit the ground first...?
yup! :biggrin:
tiny-tim said:
yup! :biggrin:
Thank you so much for helping me work that out. It's amazing that such a common assertion
("heavy and light objects fall at the same rate") is fundamentally incorrect. How did that happen?
galileo first demonstrated it …
i don't know whether he pointed out that it only works exactly in a vacuum
  • · Replies 22 ·
23K
  • · Replies 165 ·
  • · Replies 24 ·
