hammertime said:
If cosmological natural selection holds, then does that mean that matter that enters a black hole isn't destroyed? Would it pass into another universe unharmed?
I respect that you are probing into this and asking questions.
Maybe someone else would give you different answers from mine, which could be more satisfactory for you.
I will nevertheless tell you my personal take on it. which is that the testable hypothesis is all that matters. The hypothesis is simply that our list of parameters (particle masses, coupling constants etc) is a local optimum for black hole abundance.
If turns out not to be true then we forget the whole thing. If after some years of trying nobody can falsify it by showing a variation of constants that would increase production then that would be very surprising.
Why should our parameters be optimal for making black holes??!
In that case one can ask about details, like what happens to the matter that undergoes the bounce?
Now you are already asking "what happens to the matter that undergoes the bounce?"
That as I see it is not part of Smolin's hypothesis. It is not part of his evolution theory.
BUT you can begin to find out what LQC says happens to the matter, for whatever that is worth. You can read what Ashtekar and Bojowald and others have to say about the bounce. They say in LQG there is a threshold density at which quantum effects dominate classical and cause a different relation between matter and geometry, making gravity effectively repellent. They say the critical density is around 80 percent of Planck.
That would be round 10
93 times the density of water, I guess.
In LQG there is also the idea that matter and geometry arise from the same fundamental elements----the same fundamental degrees of freedom describe both matter and space at a microscopic level.
Lee Smolin and halfdozen other researchers are currently working on one possible way to make this mathematically explicit---but it has always been a vague notion present in LQG community which people try various ways to make rigorous.
The idea is that when a region of spacetime and matter collapses to a near-planck density, then you can no longer any more say what is matter and what is space. they are reduced to the same thing-----the primitive microscopic degrees of freedom from which both arise in cooler more relaxed less concentrated conditions.
You should disregard what is in red there because it is just my personal take on a persistent idea that I keep seeing in various forms but has not been stabilized.
this just just my personal thought: I don't think people yet know, or have even the beginnings of a good idea, about what happens to matter during the cosmological bounce.
or during the black hole bounce (if there is one.) And ordinary conservation laws which require a separation of space and matter do not seem likely to apply without change. Thermodynamics rules which depend on an observer, and various conventions involving temperature equilibrium and heat-engines also seem unlikely to apply without change.
At a bounce, I mean, where the energy density approaches Planck level.
So I would have to conclude that your question about "what happens to matter in a bounce?" is a very good question, but currently unanswerable.
Also it should be asked to Ashtekar, Singh, Bojowald etc. It should not be asked of Smolin because his evolution hypothesis is of a general nature that does not depend on details like that. All he does is challenge you to figure out a way to modify standard model numbers that would get us more holes----in other words he challenges you to show that our numbers are not perfect already for making holes. this challenge does not depend on specifics of any bounce mechanism.
