What Temperature Gives a 25% Population Probability at 7.00 eV in Copper?
The discussion focuses on determining the temperature at which the probability of populating an energy state at 7.00 eV in copper (with a Fermi energy of 6.95 eV) equals 25%. The Fermi-Dirac distribution formula, f(E) = 1/(1+e^((E-EF)/kT)), is employed to solve the problem. The calculated temperature of 3.2979e21 K is deemed incorrect, as it exceeds realistic values for metals. The correct Fermi temperature for copper, based on its Fermi energy, is approximately 80,654 K, indicating a significant error in the initial calculation.
  • Understanding of Fermi-Dirac distribution
  • Knowledge of Fermi energy and temperature concepts
  • Familiarity with the Boltzmann constant
  • Basic principles of statistical mechanics
  • Review the Fermi-Dirac distribution and its applications in solid-state physics
  • Study the relationship between Fermi energy and Fermi temperature
  • Explore the implications of high temperatures in metals and their electron behavior
  • Investigate common mistakes in calculations involving statistical mechanics
Students and professionals in physics, particularly those studying solid-state physics, thermodynamics, and statistical mechanics, will benefit from this discussion.
viviane363
Pleas can you help me figure out what I do wrong?
At what temperature is the probability that an energy state at 7.00 eV will be populated equal to 25 percent for copper (EF = 6.95 eV)?
The formula for the fermi-Dirac Distribution is f(E) = 1/(1+e^((E-EF)/kT))
Looking at the problem I figured that f(E) = 25%=0.25 and E-EF=7.00 - 6.95 = 0.05eV
solving for T and found that T=3.2979e21 K, but it doesn't seem to be the right answer, why?
Hmmm... That seems a bit much. What Boltzmann constant are you using? And double check your work, because I get a different answer than you.
That could well be the right answer (not sure of the exact answer, but you will get a big number). Metals have very high fermi temperatures - you can look at it in the following way. Fermi energy levels cannot be multiply-occupied. If that metal was made of bosons, it would have a temperature of 10^21 K because of where the highest energy electrons are.
That is way too large of a temperature. Hah, that is hotter than 1 second after the big bang. Also, the temperature of the Fermi energy is not even close to that. A Fermi energy of 6.95 eV has a Fermi temperature of 80,654 K.
viviane363 must have made a mistake somewhere in the calculation. Because I used the exact same formula and I got a completely different answer. But I think she forgot about this thread.
