Ferris Wheel Problem: Find Donna's Position After 36s
  • Context: MHB
  • Thread starter Thread starter fluffertoes
    Wheel
The discussion revolves around modeling the motion of Donna on a Ferris wheel, specifically focusing on deriving parametric equations for her position over time and calculating her coordinates after 36 seconds. The context includes mathematical reasoning and technical explanations related to trigonometric functions and their application in modeling circular motion.
  • One participant proposes parametric equations for Donna's motion as x(t) = 50Sin(pi*t/10) and y(t) = 50Cos(pi*t/10) + 55, seeking verification of their correctness.
  • Another participant presents an alternative set of equations, x(t) = -50Sin(pi*t/10) and y(t) = -50Cos(pi*t/10) + 55, and calculates Donna's position after 36 seconds, arriving at different coordinates.
  • Several participants question the use of negative cosine in the equations, discussing the implications of the Ferris wheel's clockwise motion and its effect on the trigonometric functions used.
  • One participant explains that the negative cosine function reflects the clockwise motion of the Ferris wheel, detailing the angular displacements and their relationship to the rider's height above ground.
  • Another participant suggests plotting points to visualize the motion and confirms that the y position curve remains valid while reflecting on the x position curve due to the direction of motion.
Participants express differing views on the correct parametric equations and the interpretation of the motion direction, leading to multiple competing models without a consensus on which is correct.
There are unresolved questions regarding the assumptions made about the direction of motion and the resulting equations, as well as the implications of using sine and cosine functions in this context.
fluffertoes
HELP!
Donna is riding a 100 foot diameter Ferris Wheel with a center located 55 feet above the ground. Assume the center of the ferris wheel is on the y-axis, and that the ferris wheel turns 1 revolution every 20 seconds in the clockwise direction.
a. Write parametric equations to model Donna's motion at any time if she is at the bottom of the wheel at time t=0.
So here, I found my two equations, please check to see if they are correct!
x(t)= 50Sin(pi*t)/10)
y(t)= 50Cos(pi*t)/10) + 55
b. What would Donna's position (x,y) be after 36 seconds?
I inputted 36 as t in the above equations and solved. I ended up with (-47.553, 70.451). Are both of my answers here (the equations and the coordinates at the time t=36) correct?
This is how I would answer the questions (with the parameter time $t$ measures in seconds and $x(t),\,y(t)$ measured in ft.):
a).
$$x(t)=50\cos\left(-\frac{2\pi}{20}t-\frac{\pi}{2}\right)=-50\sin\left(\frac{\pi}{10}t\right)$$
$$y(t)=50\sin\left(-\frac{2\pi}{20}t-\frac{\pi}{2}\right)+55=-50\cos\left(\frac{\pi}{10}t\right)+55$$
b.)
$$\left(x(36),y(36)\right)=\left(-50\sin\left(\frac{\pi}{5}18\right),-50\cos\left(\frac{\pi}{5}18\right)+55\right)=\left(25\sqrt{\frac{1}{2}(5+\sqrt{5})},55-\frac{25}{2}(\sqrt{5}-1)\right)\approx(47.55,39.55)$$
Why is cos negative in your equations??
Consider:
$$u(\theta)=\sin\left(-\theta-\frac{\pi}{2}\right)=\sin\left(-\left(\theta+\frac{\pi}{2}\right)\right)$$
Now, since sine is a odd function, this means $\sin(-x)=-\sin(x)$, and so we now have:
$$u(\theta)=-\sin\left(\theta+\frac{\pi}{2}\right)$$
Now, using the angle sum identity for sine:
$$\sin(\alpha+\beta)=\sin(\alpha)\cos(\beta)+\sin(\beta)\cos(\alpha)$$
We have:
$$u(\theta)=-\left(\sin(\theta)\cos\left(\frac{\pi}{2}\right)+\sin\left(\frac{\pi}{2}\right)\cos(\theta)\right)=-\left(\sin(\theta)\cdot0+1\cdot\cos(\theta)\right)=-\cos(\theta)$$
Another way to look at it is to again consider:
$$u(\theta)=\sin\left(-\theta-\frac{\pi}{2}\right)=\sin\left(-\left(\frac{\pi}{2}-(-\theta)\right)\right)$$
Using the fact that sine is odd, we have:
$$u(\theta)=-\sin\left(\frac{\pi}{2}-(-\theta)\right)$$
Using a co-function identity $\sin\left(\dfrac{\pi}{2}-x\right)=\cos(x)$, we obtain:
$$u(\theta)=-\cos(-\theta)$$
Using the fact that cosine is an even function (i.e. $\cos(-x)=\cos(x)$), we have:
$$u(\theta)=-\cos(\theta)$$
So would it always be negative for other ferris wheel problems?
Consider that the way we have our coordinate axes oriented, the rider begins on the $y$-axis. Now, as the wheel begins moving in a clockwise direction, the rider's height above the ground increases and after an angular displacement of $$\frac{\pi}{2}$$ radians, the rider is at the same level as the hub of the wheel, and after a total angular displacement of $\pi$ radians, the rider is at the maximum height. After that, the rider's height begins to decrease. This is how a negative cosine function behaves...does that make sense?
If we think about the unit circle, the rider begins with an angular displacement of $$-\frac{\pi}{2}$$ radians (the bottom of the circle), and when the wheel moves in the clockwise position, the angular motion is in the negative direction...that's why I used as the argument for the trig. functions:
$$\theta=-\frac{2\pi}{20}t-\frac{\pi}{2}$$
often times it helps to first make a sketch of the individual position graphs by plotting a few points
for x as a function of time, x(0) = 0, x(5) = 50, x(10) = 0, x(15) = -50, and x(20) = 0
plot those points on a graph of position vs time and note the points define a sine curve with equation x = 50sin(pi/10*t)do the same for y as a function of time, y(0) = 5, y(5) = 55, y(10) = 105, y(15) = 55, and y(20) = 5
plot those points on a graph of position vs time and note the points define an "inverted" cosine curve with an upward shift , equation y = -50cos(pi/10*t) + 55
You have the Ferris wheel moving in a counter-clockwise direction. (Shake)
Oops ... well, the y position curve is still good. Just reflect the x position curve over the horizontal axis making A = -50
That doesn't take away from your good advice of plotting points to see what the sinusoidal parametric curves are going to look like. :D
12K
