mrtnelson8
- 2
can I use ferrolfluid as a lubricant between a cylindrical neodymium magnet and a pvc pipe that the magnet fits snugly in(still will move back and forth in the pipe but does experience a little friction)?
sophiecentaur said:That's a different sort of attraction.
Ferrofluid is a magnetic liquid composed of tiny magnetic particles suspended in a carrier fluid, such as oil or water.
When a magnetic field is applied, the ferrofluid particles align and form a thin layer between two surfaces, reducing friction and providing lubrication.
Ferrofluid has a high thermal stability, can operate under extreme pressure, and is resistant to oxidation and corrosion. It also has a low coefficient of friction, making it an efficient lubricant.
Ferrofluid can only be used in applications where a magnetic field can be applied, so it may not be suitable for all types of machinery. It also has a limited load-bearing capacity and may not be as effective in high-speed applications.
Yes, ferrofluid can be used in combination with other lubricants to enhance their properties. It can also be used in oil-based or grease-based lubricants to improve their magnetic properties.
