Field line near the electrodes for the different electrode
The density of electric field lines near electrodes varies based on the electrode type, influencing the force exerted on nearby charges. Denser field lines indicate a stronger electric field, leading to faster acceleration of charges in those regions. The relationship between field density and force is described by the inverse square law, where force diminishes with distance. Understanding these concepts is crucial for applications in electrostatics and charge manipulation. The discussion emphasizes the significance of field line density in determining charge behavior near electrodes.
xswtxoj
1. Can someone explain the density of the field line near the electrodes for the different electrode.
2. How would the different field densities described above affect the force on a charge?
www.nmfrc.org/subs/history/cddfig05.jpg
is an example of the field lines, which were once considered lines of force (faraday). charges will accelerate faster in denser fields, which exist very close to the electrodes. everything is summing fields, and the fields in question are 1/r^2 for the force.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
