Final exam - help- Inverse function Theorem
To find g'(y) for the inverse function of f(x) = sinh(x), apply the Inverse Function Theorem, which states that g'(y) = 1/f'(x). The derivative f'(x) is cosh(x), which can be expressed as (e^x + e^-x)/2. Instead of using exponentials, it's more effective to use the identity cosh(x) = √(1 + sinh(x)^2) to rewrite it in terms of y. Thus, g'(y) simplifies to 1/√(1 + y^2).
IntroAnalysis
Let f(x) = sinh(x) and let g be the inverse function of f. Using inverse function theorem, obtain g'(y) explicitly, a formula in y.
Okay the Inverse function Theorem says (f^-1)'(y) = 1/(f'(x))
If f is continuous on [a, b} and differentiable with f'(x)\neq0 for all x\in[a, b]. Then f is 1-1 and f^-1 is continuous and differentiable on f(a,b).
The derivative of f(x) sinh(x) is cosh = (e^x + e^-x)/2
How do I get g'(y) as a formula in y? Right now, I have 2/(e^x + e^-x)
You have ##\frac 1 {f'(x)} = \frac 1 {\cosh x}##, and you have ##y=\sinh x##. It is almost always a mistake to put in exponentials. Use the basic sinh and cosh identity to express ##\cosh x## in terms of ##y##, given what you have.
Thanks so much, you save me from messing with exponents! Since I know cosh (x) = √(1 + sinh(x)^2 = √1 + y^2 !
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
