Find A and B so that F(x) is a Differentiable Function
The problem involves finding values for A and B that make a piecewise function differentiable. The function is defined as f(x) = Ax^2 - Bx for x ≤ 1 and f(x) = Alnx + B for x > 1.
  • Exploratory, Assumption checking
  • The original poster attempts to set the two pieces of the function equal to each other and derive conditions for differentiability. They explore equations derived from substituting x = 1 into the function and its derivative, leading to conflicting results regarding the values of A and B.
Participants are engaged in exploring the problem, with some expressing confusion about the original problem statement. There is a suggestion of a potential typo in the problem, which may change the approach to finding A and B. The discussion reflects a lack of consensus on the correct interpretation of the problem.
There is mention of a possible typo in the problem statement that could affect the values of A and B, as indicated by the original poster's update regarding the function's definition.
Jakey214
Find the values of a and b that make f a differentiable function.
Note: F(x) is a piecewise function
f(x):
Ax^2 - Bx, X ≤ 1
Alnx + B, X > 1
Made the two equations equal each other.
Ax^2 - Bx = Alnx + B
Inserting x=1 gives,
A - B = B, which is also A - 2B = 0, which also means A = 2B
Deriving the equation,
2Ax - B = A/X
Inserting x=1 here gives,
2A - B = A, which is also A - B = 0, which also means A = B
By then I'm stumped here.
I try to eliminate either A and B with,
A - B = 0
A - 2B = 0
In the end, both A and B would have to equal zero, both of which doesn't work.
If I have A = 2B then,
F'(x): A - B = 0 ⇒ 2B - B = 0 ⇒ B = 0
As said before, B = 0 would not be the right answer, as far as I know at least.
If A = B, then
F(x): A - 2B = 0 ⇒ B - 2B = 0 ⇒ B = 0
Once Again, B equaling zero would not work.
Right now, I'm convinced this problem is virtually impossible.
Are you sure you copied the problem down correctly?
Yep, that's exactly what it says.
Then I'm stumped too. Perhaps someone else will have a solution.
So what is wrong with ##f(x) \equiv 0##? That's a perfectly good differentiable function.
UPDATE:
My Math Teacher just said it was a typo, where he forgot to add a negative two, so that the piecewise function would be:
f(x):
Ax^2 - Bx - 2, X ≤ 1
Alnx + B, X > 1
Now solving it, I got A = -2 and B = -2.
  • · Replies 18 ·
  • · Replies 20 ·
