m_s_a
- 88
find a,b,c
a+b+c=180
tana+tanb+tanc= sq.(3)
a+b+c=180
The discussion revolves around a problem involving angles a, b, and c that sum to 180 degrees, with a focus on their tangent values. Participants are exploring the relationships between these angles and their tangents, particularly in the context of the equation involving the sum of tangents equating to the square root of 3.
The discussion is ongoing, with participants raising valid points about the constraints and assumptions of the problem. Some have suggested alternative interpretations of the equations, while others express uncertainty about the original question's validity.
There is a noted concern regarding the lack of sufficient equations to solve for the three unknowns, as well as potential misinterpretations of the angle sum. Participants are considering the implications of these assumptions on the problem's solvability.
div curl F= 0 said:Not too sure if this is solvable in general as you only have 2 equations but 3 unknowns. Are there any other equations/constraints that you didn't post up?
Generally, you need n equations/constraints to solve for n unknowns.
