Find a sequence convering to sqrt(2)
  • Thread starter Thread starter kidsmoker
    Sequence
The discussion focuses on finding a sequence that converges to the limit of \(\sqrt{2}\) using recurrence relations. The proposed sequence is defined by the relation \(a_{n+1} = \frac{1}{2 + a_{n}}\), leading to the equation \(l = \frac{1}{2 + l}\) to find the limit. The positive root of this equation is \(l = -1 + \sqrt{2}\), which establishes the limit of the sequence. However, a key point raised is the necessity of proving the convergence of the sequence to \(\sqrt{2}\), which is not explicitly required in the current module.
  • Understanding of recurrence relations in sequences
  • Familiarity with limits and convergence in calculus
  • Knowledge of solving equations involving limits
  • Basic concepts of mathematical proof techniques
  • Study convergence criteria for sequences in real analysis
  • Learn about bounded and monotonic sequences
  • Explore different methods for proving convergence of sequences
  • Investigate other recurrence relations that converge to irrational numbers
Students in mathematics, particularly those studying calculus or real analysis, as well as educators looking for examples of sequences and convergence proofs.
kidsmoker
Find a sequence whose limit is \sqrt{2}.
The work preceeding this was about using recurrence relations to find sequences with desired limits, so that's the method they want me to use.
We can find the limit of the sequence given by
a_{n+1} = \frac{1}{2+a_{n}} by noting that a_{n+1} and a_{n} both have the same limit. So we can write
l = \frac{1}{2+l} and find the positive root of that: l = -1 + \sqrt{2}. This is the limit of the sequence.
I can then just add on one to each term to give a sequence with limit \sqrt{2}. Is this all they want me to do you think? Or is there a way to get write another sequence involving a_{n+1} and a_{n} which gives the desired answer?
Thanks.
There are gajillions of ways to answer this problem; yours seems fine.
I do have one question, though: were you merely asked to find a sequence, or are you also expected to prove that the sequence converges to \sqrt{2}? If the latter, I would like to point out that your work shows
If the sequence converges, then it converges to \sqrt{2}.​
However, you never showed that the sequence converges, and therefore you cannot conclude that it converges to \sqrt{2}.
Yeah I see what you mean. If it was Analysis then i'd have to prove it by showing it's bounded and increasing or whatever. But this module doesn't seem to bother with that. Thanks.
  • · Replies 17 ·
