What is the vector orthogonal to <-3,2,0> and <0,2,2> with the form <1,_,_>?
  • Thread starter Thread starter Whatupdoc
    Orthogonal Vector
The discussion focuses on finding a vector orthogonal to the vectors <-3, 2, 0> and <0, 2, 2> in the form <1, _, _>. The initial attempt using the cross product resulted in an incorrect vector <2, 3, 6>. The correct approach involves recognizing that the unique vector perpendicular to two non-collinear vectors can be scaled, leading to the solution <1, 1.5, 3> by dividing the initial result by 2. This emphasizes the importance of scalar multiplication in vector calculations.
  • Understanding of vector operations, specifically cross products
  • Familiarity with the concept of orthogonality in vector spaces
  • Basic knowledge of scalar multiplication in linear algebra
  • Ability to manipulate and simplify vector components
  • Study the properties of cross products in three-dimensional space
  • Learn about vector projections and their applications
  • Explore the concept of linear independence and its relevance to vector orthogonality
  • Practice problems involving orthogonal vectors and scalar multiplication
Students and professionals in mathematics, physics, and engineering who require a solid understanding of vector operations and their applications in solving geometric problems.
Whatupdoc
Find a vector orthogonal to both <-3,2,0> and to <0,2,2> of the form
<1,_,_> (suppose to fill in the blanks)
well i thought the cross product would do the trick, but i keep getting the wrong answer.
I|2 0| - j |-3 0| + k |-3 2|
|2 2| |0 2| |0 2|
(format is kinda messed up, but I am pretty sure you can tell how i had it set up)
i(4-0) -j(-6-0)+ k(-6-0) = 4i+6j+6k = 2i+3j+6k
so the answer should be <2,3,6> which is obviously incorrectly cause i don't even have a 1.
|2 2| |0 2| |0 2|
assuming that's the correct answer, why don't you multiply by a scalar
|2 2| |0 2| |0 2|
You're pretty much right, apart from the sloppy sign change that crept in towards the end for no reason (-6k not +6k). Is it specified in the question that all components must be integers? If not, I would suggest simply dividing your answer by 2.
It can't be specified that the components are all integers because there is only one unique vector that is perpendicular to two non-colinear vectors, up to constant multiples. So dividing gives the unique answer to the problem.
I suppose that I was being over cautious that I could have made some kind of mistake or overlooked something but you are right of course.
thanks a lot, dividing by 2 worked. i had the -6 in on my paper, but when i typed it on here, everything was messed up including the answer i gave at the end. i was really sleepy awhile i was typing it, thanks agian for the help
  • · Replies 17 ·
