Find all solutions to Sin 2x = 2Tan 2x
  • Thread starter Thread starter powp
    Sin
The equation Sin 2x = 2Tan 2x leads to the conclusion that cos 2x = 2, which has no real solutions since the cosine function cannot exceed 1. The transformation of the equation reveals that the only viable solutions arise from Sin 2x = 0. This results in x = kπ, where k is any integer, representing the complete set of real solutions. The discussion emphasizes the importance of recognizing the implications of the double angle in trigonometric identities. Ultimately, the only real solution to the original equation is x = kπ.
powp
Is this correct??
Hello All
I need to find all solutions to the following did i do it correct?
Sin 2x = 2Tan 2x
2Sinx Cosx = 2(2Tanx / 1-Tan^2x)
Sinx Cosx = (2(Sinx / Cosx)/(cos^2x-Sin^2x / Cos^2x))
Sinx Cosx = 2(Sinx / Cosx) X (Cos^2x / cos^2x-Sin^2x)
Cosx = 2 (Cosx / Cos^2x - Sin^2x)
1 = (2 / Cos^2x - Sin^2x)
Cos^2x - Sin^2x = 2
1 - Sinx^2 - Sin^2x = 2
2Sin^2x = -1
Sin^2x = -1/2
Sinx = -1/SQROOT(2)
Is this correct??
Mathematics news on Phys.org
Nope.
Remember that Tan(2x)=Sin(2x)/Cos(2x)
Thus, you may rewrite your original equation as:
\sin(2x)(1-\frac{2}{\cos(2x)})=0
EDIT:
Find out the requirements for either factor to be zero; you should find that one of those requirements is impossible to achieve.
You certainly made a mistake. You arrived to the equation:
cos^2x - sin^2x = 2
but
cos^2x - sin^2x = cos 2x
So you have
cos 2x = 2
This has no real solution.
proceeding your development you got
sin^2x = -\frac{1}{2}
whose solution is
sin x = -\frac{i}{\sqrt{2}}
Let's call tan(x) "t"
then we have 2*t/(1+t^2)=4*t/(1-t^2)
we must exclude that t=+-1 to give the expression a meaning. (x!=pi/4+kpi/2)
then we obtain one solution: t=0 (x=kpi)
we have if t!=0: 1-t^2=2+2t^2 that is 3t^2=-1, which has no real solution (anyway you could be interested in finding the complex ones)
So the only real solution is x=k*pi, where k belongs to Z
Arildno Which side are you talking about?
SGT: Did have COS2x = 2 but was told by a classmate that I did the problem wrong. I kind of get confussed with the 2x in the statement. What does it really mean.
I did not follow all your development because your notation is almost unintelligible, but I think your classmate is right. You probably made some mistake.
The 2x means the double of the arc x. If x = \frac{\pi}{3} for instance, then 2x = \frac{2\pi}{3}
1. Our problem is to determine the set of x-values that makes
\sin(2x)=2\tan(2x)
into a TRUE statement.
That is, we want to find the "solutions" to that equation.
2. We have, for all x-values the identity \tan(2x)=\frac{\sin(2x)}{\cos(2x)}
where with "all x-values" should be understood all real values except those for which \cos(2x)=0 (i.e, when tan(2x) is infinite).
3. Given the identity in 2., we may rephrase our original problem into finding the solution set for the following equation:
\sin(2x)=2\frac{\sin(2x)}{\cos(2x)}
4. Now, adding any arbitrary number to both sides of an equation won't change the solution set we're after, so by adding -sin(2x) to both sides, we can rephrase our problem into determining the solution set to the following equation:
2\frac{\sin(2x)}{\cos(2x)}-\sin(2x)=0
5) Arbitrary real numbers a,b,c fulfill the distributive law: a*(b+c)=a*b+a*c
Recognizing the common factor sin(2x) on the left-hand side expression in the equation given under 4., we may rephrase our problem into determining the solution set of the following equation:
\sin(2x)*(\frac{2}{\cos(2x)}-1)=0
6) Now, if the product of two numbers is to be zero, then at least one of the numbers themselves must be zero.
Therefore, if the equation under 5. is to be a true statement, then we must have EITHER:
\sin(2x)=0
OR:
\frac{2}{\cos(2x)}-1=0
7. Let's look at the last one.
If we are to have \frac{2}{\cos(2x)}-1=0, then this is equivalent to demanding \cos(2x)=2
But, since the cosine is always less than or equal to 2, we see that the statement:
\cos(2x)=2 cannot have any solutions at all
(that is, whatever number "x" you substitute into the expression on the left-hand side, will never make cos(2x) equal to 2.
8.
Thus, we may conclude, that the solution set to our original problem will be the solution set of the equation:
\sin(2x)=0
