Find an expression of g(x) in terms of x for an equation f(x)?
  • Thread starter Thread starter fs93
    Expression Terms
The discussion focuses on finding expressions for g(x) in terms of x based on the function f(x) = x^3. For the equation f[g(x)] = x + 1, the correct expression is g(x) = ∛(x + 1). However, for g[f(x)] = x + 1, the expression requires a more complex approach, as simply using g(x) = ∛(x) + 1 does not satisfy the equation. The correct method involves subtracting 1 from the input, taking the cube root, and then adding 1 to achieve the desired output.
  • Understanding of cubic functions and their properties
  • Knowledge of inverse functions and function composition
  • Familiarity with cube roots and their mathematical implications
  • Basic algebraic manipulation skills
  • Study the properties of inverse functions in detail
  • Learn about function composition and its applications
  • Practice solving equations involving cube roots and polynomial functions
  • Explore methods for deriving functions through trial and error
Students studying algebra, particularly those focusing on functions and their inverses, as well as educators looking for examples of function composition and manipulation.
fs93
The function f is defined by f(x) = x^3
Find an expression for g(x) in terms of x in each of the following cases.
(a) f [ g(x) ] = x+1
(b) g [ f(x) ] = x+1
I got the same answer both times. g(x) = cubic route (x+1). Because if I put the cubic route of x+1 in f(x), it is cubed, and I'm left with x+1.
For (b) its the same. If I have cubic route of (x+1), and then cube it, I'm left with x+1. Is this correct?
I'd appreciate some help :)
The first one is okay. For the second one, if g(x) = \sqrt[3]{x + 1} then g(f(x)) = \sqrt[3]{x^3 + 1} \neq x + 1.
Why don't you try g(x) = \sqrt[3]{x} + 1
Thanks, that really clears things up.
But is there a method that I can always apply to such a question?
Or do you always have to keep doing trial and logic until you find the correct function?
For the type of question you posted, it's more or less using your logic and just seeing what the correct function should be, combined with some trial and error.
That's what I'm going to practice then. Thanks a million.
For b, you want to find g so that g(x3 + 1) = x + 1, so you need to figure out what g needs to do to an input value so that the output is x + 1.
To get from x3 + 1 to x + 1, g would need to:
  1. Subtract 1 from the input value.
  2. Take the cube root (not route) of the value from step 1.
  3. Add 1 to the value from step 2.
JG89's suggestion, g(x) = \sqrt[3]{x} + 1
doesn't do the first step, just the second and third, so doesn't work as the formula for g(x).
  • · Replies 20 ·
