Find average and rms values of the waveform
The discussion focuses on calculating the average and RMS values of a given waveform. Participants clarify that the RMS value is computed using the integral of the square of the current over one period, while the average value is calculated similarly but without squaring the function. There is confusion regarding the time intervals used in the solution, particularly why the waveform is not considered over the entire range from 0 to 6 seconds. It is established that the correct period T for the waveform is 3 seconds, as it encompasses one complete cycle of the repeating signal. The conversation emphasizes the importance of identifying the correct time interval to accurately compute both average and RMS values.
DODGEVIPER13
The problem is located here http://www.chegg.com/homework-help/determine-average-rms-value-waveform-depicted-fig-1136-chapter-11-problem-26e-solution-9780073529578-exc
Rms=sqrt(1/T∫ from 0 to T of i(t)^2 DT )
Average= couldn't find an equation in book??
Ok so I did it on my own and I'm trying to figure out why in the solution that the person posted. Is i(t) only written for 3 time intervals 0<t<2, 2<t<3, and 3<t<5. Why is there not a 4th 5<t<6 where i(t) would equal -9 A. BTW this is the first part if it wasn't clear. Furthermore how is T=5 I would think it would be 2 as the square wave gets its maximum at -9 and it lasts for 2 and 3? Also what is the equation for average value of current? And more of the same on the second part of the problem why did they only do parts of the waveform?
Or is the solution incorrect
here is my work
It's a repeating waveform. The average (or rms) over one cycle (period) is the same as over all periods. So you need to identify one period and work with that. Looks to me like the time interval from 0 to 3 would cover one period of the repeating signal (the interval from 3 to 6 is an exact repetition).
The mean is calculated in the same way that the mean is calculated for the rms, only the function isn't squared. That is,
$$mean = \frac{1}{T}\int_{t_o}^{t_f}i(t)dt$$
ah so T=3 then because it covers the time from its minimum to its max.
T = 3 because it covers one period of the waveform. A period is the repeating unit of the waveform.
ok thanks
