Find Centroid of Shape: X & Y Dimensions from Point O
  • Thread starter Thread starter physicx_1
    Centroid Shape
To find the centroid of a complex shape, it is essential to decompose the shape into simpler geometric figures. Each smaller shape's area and centroid must be calculated using point O as a reference. After determining the centroids of the individual shapes, their moments of area should be summed to find the overall centroid of the larger figure. This involves creating a table to organize the areas and centroids of the smaller shapes. Ultimately, the total area and centroid can be derived from these calculations.
physicx_1
CALCULATE POSITIONS OF THE CENTROID OF THE SHAPE SHOWN BELOW
GIVE DIMENSIONS FROM POINT O ALONG THE HORIZONTAL X-DIRECTION, AND THE VERTICAL Y-DIRECTION.
[PLAIN]http://img402.imageshack.us/img402/738/unledgj.jpg
I know you have to find the middle of the distances in the symmetry. does the c of g line somewhere in the center line of the diagram?
I'm really stuck, please help
Hint: Try breaking up this complicated shape into several simpler ones.
but once i do that, and find the c of g of those shapes, how do i relate them together?
can anyone help?
I know to break into simpler shapes. and I did. however there are some irregular shapes even if I was to break them into smaller ones. what do I do to deal with those?
Once you have broken the larger figure into smaller pieces, set up a table where you calculate the area of each smaller piece and determine the c.g. of each of the pieces using point O as the reference. Calculate the moment of area of each of the pieces. Add up the areas and moments. Find the total area and c.g. of the larger figure.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
