Find Displacement of Car: Math Homework
The discussion focuses on calculating the resultant displacement of a car that travels 18.2 km north and then 43.2 km at 53 degrees west of north. The initial calculations for the components of the vectors are debated, particularly the angles used for Bx and By. There is confusion regarding the correct interpretation of the angle for part b of the problem, with suggestions to use the law of cosines instead of the Pythagorean theorem for accurate results. The correct angle for the resultant vector is clarified as 127 degrees, which is derived from the proper understanding of the geometry involved. The conversation emphasizes the importance of correctly interpreting vector directions and applying the right mathematical principles.
delfam
car travels 18.2km due north then 43.2km at 53 degrees west of north. Find magnitude of car's resultant displacement.
b.) calculate the direction of the car's resultant displacement, measured counter-clockwise from the northerly direction.
Ax = 18.2sin(90) =18.2 Ay = 18.2cos(90) = 0
Bx = 43.2sin(143) = 26 By = 43.2cos(143) = -34.501
Cx = 44.2 Cy = -34.501
44.2^2 + -34.501^2 = 3143.82, square root of that = 56.07
arctan(-34.504/44.2) = -37.98 degrees
so part b says counter-clockwise from north, so wouldn't it be from 90 degrees so should the angle be 127.98? I entered that as an asnwer and it's wrong so not sure what I did wrong.
when you did Bx and By, where did you get 43.2 and 143 degrees?
typo, it was due north 43.2km not 432, the 143 degrees is when it says 53 degrees west of north, north is 90, so 90 + 53 = 143. I already got that part right, I just don't understand the wording on part b.
recheck your math for Bx and By. Bx should be 260 and By should be -345. Also, you're using the Pythagorean theorem when you should be using law of cosines. the angle across from the resultant vector should be 90 + (90 - 53) = 127. In other words, it's 53 degrees from the vertical not the horizontal.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
