omc1
- 100
omc1 said:the change in T=+295, i drew a picture we are looking for the height the the bar rises...
omc1 said:i thought that for C to K conversion you add 273?
omc1 said:um the K degree is the same as the C degree...so when is the appropriate time to use 273.15?
Right. That's the temperature change (and it's the same in °K or °C).omc1 said:ok, I think I see now...so I should use 22 instead of 295...
The formula you've used will give you the change in length. Add the change in length to the original length to get the new overall length.is the formula I used right, I am still confused about how to solve this...
omc1 said:ok, when I did that I got .0171 m then I added 2.79 and got 2.81 m but that's not working...it doesn't make sense to do that because it was the distance it rises...
omc1 said:does it represent the new length of the bar?
omc1 said:right, it split then rose, so i don't understand how to find that height...
omc1 said:so i need to use the Pythagorean theorem
(2.81/2)^2-(2.79/2)^2=b^2 i got 0.167 m which isn't right..
omc1 said:ok thank you! thank worked finally :)
