Analyzing Current Flow in Parallel and Series Battery Configurations
  • Thread starter Thread starter auk411
    Resistance
The discussion focuses on analyzing the current flow in two identical batteries with an electromotive force (emf) of 12 V and an internal resistance of 0.200 Ω, connected to an external resistance R, either in parallel or in series. When R is set to 2.00 times the internal resistance (R = 2.00r), the current i can be determined using the equation ε = ir + (2i)R. Participants emphasize the importance of understanding the symmetry in parallel configurations and suggest drawing the circuit for clarity.
  • Understanding of Ohm's Law
  • Knowledge of circuit configurations (series and parallel)
  • Familiarity with electromotive force (emf) and internal resistance
  • Ability to manipulate algebraic equations
  • Calculate current flow in series and parallel battery configurations
  • Explore the effects of varying external resistance on circuit performance
  • Learn about Kirchhoff's laws for circuit analysis
  • Investigate battery capacity and discharge characteristics
Students studying electrical engineering, educators teaching circuit theory, and hobbyists experimenting with battery configurations.
auk411
Two identical batteries of emf ε = 12 V and internal resistance r = 0.200 Ω are to be connected to an external resistance R, either in parallel or in series. If R = 2.00r Ω, what is the current i in the external resistance in the (a) parallel and (b) in the series arrangements?
By symmetry, when the two batteries are connected in parallel the current i going
through either one is the same. So from ε = ir + (2i)R with r = 0.200 Ω and R = 2.00r, we
get ... etc.
I have no idea what the above means. What is going on?
While I appreciate the help, can you please give more than a sentence or two. I have found shortness = unhelpful response (not necessarily true, but there does seem to be a correlation).
get ... etc.
Sorry, but this will be rather short.
Where did you get the following information, if you don't understand it? (I think that's what you indicated.)
"By symmetry, when the two batteries are connected in parallel the current i going
get ... etc."​
It looks like you could plug-in the values for r, R, and ε, to find the current, i .
The information would appear to be a quote from a solution, perhaps from a textbook example problem.
It might help if auk411 were to draw the circuit in question and label the currents.
  • · Replies 24 ·
