Find final rotational kinetic energy without knowing radius?
The discussion focuses on calculating the rotational kinetic energy of a basketball (0.125 kg) rolling off a table at 4.50 m/s and falling 1.10 m. The final rotational kinetic energy is determined to be 0.506 J. Participants clarify that the moment of inertia for a basketball is that of a thin spherical shell, and emphasize that the radius is not needed for the calculation as it cancels out. The key equations used include KE rotational (KE rot = 0.5 I ω²) and potential energy (PE = mgh).
  • Understanding of rotational kinetic energy (KE rot = 0.5 I ω²)
  • Knowledge of potential energy (PE = mgh)
  • Familiarity with moment of inertia for different shapes, specifically thin spherical shells
  • Basic principles of linear and angular motion
  • Learn about the moment of inertia for various geometric shapes, focusing on thin spherical shells
  • Study the relationship between linear speed and angular speed (ω = v/r)
  • Explore the concept of energy conservation in rotational dynamics
  • Investigate the effects of torque and angular momentum in rotational motion
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators seeking to clarify concepts related to kinetic energy and motion.
matxjos
A 0.125kg basketball is rolling w/out slipping on a horizontal table at 4.50 m/s when it rolls off the edge and it falls to the floor, 1.10 m below. What is the rotational kinetic energy of the ball right before hitting floor?
KE rot: .5 I w^2
KE translational: .5 m v^2
PE: mgh
Initial: I figured out KE translational and PE for the initial conditions on the horizontal surface, these are easy.
I do not know how to get K rotational energy!
Final: I used vertical constant acceleration equations to find the final velocity. Then I got the kinetic energy right before hitting the floor. Potential energy is 0.
No idea how to get K rot energy!
I've been working on this problem forever (all morning). The answer to the problem is apparently 0.506J.
HOW?!
Once the ball leaves the table there's nothing to provide torque to change its rotation, so ignore everything that happens after it leaves the table.
Write an expression for the rotation rate of the ball as it rolls. That's the ##\omega## for your rotational kinetic energy expression. What expression will you use for the moment of inertia?
(P.S. I feel that the problem author used an incorrect moment of inertia; a basketball is a thin spherical shell, not a solid sphere).
Well, a solid sphere's moment of inertia is 2/5MR^2. Is this the expression I use? I still don't know the radius...
I'm not even sure what you mean to write an expression for the rotation rate. Like in rad/s? I know how to get that from rev/min, or even m/s, but I don't know the radius. :(
Thanks for looking at this problem!
Wait, if there is no rotation after the ball leaves the table, does that mean the rotational energy is zero? Or just the same as the initial KE rot?
Solid basketballs?! That's serious training.
You'll find you don't need to. Just put in an unknown for it and it should cancel out later.
Yes. Create another unknown for this, and an equation relating it to linear speed and radius.
gneill said there'd be no change in rotation rate.
Wow, thanks, I got the answer! I didn't realize things cancel out...physics is most confusing when that has to happen. But very interesting.
Thanks haruspex and gneill! :biggrin:
  • · Replies 21 ·
  • · Replies 33 ·
  • · Replies 32 ·
