Find force box exerts on other box up incline
The discussion centers on calculating the force exerted by one box on another on an inclined plane, specifically two boxes with masses of 2 kg and 3 kg being pushed by a force of 25 N at a 30-degree angle. The initial misunderstanding involved incorrectly resolving the weight components and applying Newton's laws. The correct approach involves determining the net force acting on the system, leading to an acceleration of 5 m/s², and calculating the contact force between the boxes, which is determined to be 15 N based on the mass of the second box and the acceleration.
  • Understanding of Newton's laws of motion
  • Knowledge of free body diagrams
  • Basic principles of inclined planes in physics
  • Ability to resolve forces into components
  • Study the application of Newton's second law in systems with multiple objects
  • Learn how to draw and interpret free body diagrams for complex systems
  • Explore the effects of friction on inclined planes and how to incorporate it into calculations
  • Investigate the relationship between force, mass, and acceleration in various scenarios
Students studying physics, particularly those focusing on mechanics and inclined plane problems, as well as educators seeking to clarify concepts related to force interactions between objects.
Entr0py
A force F pushes two boxes, box 1 and box 2 up an inclined plane of 30 degrees. If F=25 N and box 1 is 2 kg and box 2 is 3 kg, what is the force exerted on the 2 kg box by the 3 kg box. Assume no friction.
F=ma.
Since the boxes' accelerations are the same, I decided to resolve the 2 kg box's weight into mgsin(theta) and mgcos(theta). Since mgcos(theta) is equal and opposite to the normal force on the 2 kg box, I thought that the magnitude of the force with which the 3 kg box exerts on the 2 kg box equals mgsin(theta) for the 2 kg box. So the answer to the problem I thought would be mgsin(theta) which would be (2 kg)(9.8 m/s^2)(30 degrees) which is 9.8 N.[/B]
Ouch, what happened to Newton's laws? The weight of an object is the force of the Earth (gravity) on the object. An objects weight never acts on another object. Try Newton's 2nd law on the system of the 2 boxes by first finding the net force acting on the system to solve for the acceleration. Then draw free body diagrams of each block separately to find the contact force between blocks, again using his laws.
ok my bad. Yeah you're right: I guess Newton's laws don't exist in my world. I think I got confused when I resolved the weight into its components. That's what happens when you do a problem too quickly. Yikes indeed
I found that the acceleration of the system is 5 m/s^2. The forces acting on the 2 kg box are its weight, normal force from incline, and the reaction force from the 3 kg box. So would the force that 3 kg box exerts on 2 kg box be (3 kg)(5 m/s^2) which would be 15 N?
Depends on which way the force vector points.
It points in the left direction, in direction of 2 kg box.
Is it parallel to the ground or the 30 degree incline?
At a 30 degree angle
I just don't see how I could resolve that force vector if it is parallel to incline
Why would the acceleration be ##5\frac{m}{s^2}##? Ask yourself if this is the same as if it were a horizontal case. Why would the incline case be the same?
Did you draw your force diagrams?
Not sure what this means.
You need to find the net force of the system. After you do that you can determine the acceleration. In this particular problem there is normal, weight due to gravity, and the 25N.
LOL my bad, got who was asking the question confused.
  • · Replies 47 ·
