Find Force From A Graph Of Potential
17 replies · 4K views
Winzer
The electric potential along the x-axis (in kV) is plotted versus the value of x, (in m). Evaluate the x-component of the electrical force on a charge of 4.05 C located on the x-axis at -13.0 m.
[tex]E_{x}= -\frac{\partial V}{\partial X}[/tex]
Ok So i drew a tangent line at x=-13 and kv[tex]\approx[/tex]62.5
I know I must perform Eq=F for the x-axis.
So I did:
[tex]E_{x}=-\frac{\partial V}{\partial X}=\frac{f(x+h)-f(x)}{h}[/tex]
[tex]\rightarrow\frac{f(-13+h)-f(-13)}{h}[/tex] I broke each cube into 5's vertically and thought 1 would be good to equall h so :
[tex]\frac{f(-12)-f(-13)}{1}[/tex] [tex]\rightarrow \frac{-125-62.5}{1}[/tex]
Sound good so far? My online HW system says I have to be really accurate with these measurements and such
I'm seeing voltage as 0 at x=-12.5, and a positive value at x=-13.
so :
[tex]\frac{f(-12.5)-f(-13)}{.5}[/tex]
Winzer said:
so :
Correct. V(-13) > 0 and dV/dx (-12.5) < 0.
But for accuracy, one wants to minimize dx, or [itex]\Delta x[/itex] in this case.
Winzer said:
so :
Yeah, what you had before was ok, but h=0.5 is better than h=1... smaller the h the better...
So how about :
[tex]\frac{f(-12.9)-f(-13)}{.9}= 34.7222kv/m \longrightarrow 34722.22 V/m[/tex]
Winzer said:
So how about :
Although you want h to be small, you want it to be big enough to accurately discriminate between two points... don't make h smaller than 1 division... 1 division on your graph should be good... I'm seeing 14 divisions between -15 and -10... so that's 0.357 per division.
so maybe use h = 0.357 which is 1 division horizontally.
-13 + 0.357 = -12.643
does f(-12.643)=125 sound accurate?
f(-13) should be greater than f(-12.643)...
from your first post you measured f(-13) at 62.5...
so one of them isn't right.
Looking at your first post... you drew the tangent at x=-13 right? Did you get the slope of the line?
Oops. I meant -125
Winzer said:
Oops. I meant -125
Hmmm... that doesn't seem right to me either... don't you think f(-12.5) = 0 ? So f(-12.643) would be positive but less than f(-13)...
The best way might just be to draw the tangent at x = -13, and then get the slope of that line as you had initially mentioned...
But I don't think it is accurate enough
what do you get as the slope?
from the top -1.875E2 kv/m
Hmmm... that doesn't look right... where does the line intersect the y- axis. where does it intersect the x - axis?
ok -250Kv/m is my slope
so I convert -250kv/m to -250000v/m times 4.05E-6 C and get -1.0125 N.
but it is wrong
